Ok so I have searched and couldn't find anything so don't bash me!
I'd like to know what a 33 in VERY GOOD condition should do, ie 1/4 mile and 0 - 100, with stock turbo maxed out, ie ~200rw.
I saw a good thread with stock times of nissan/toyota/commos for a comparison, can't find it.
In comparison to stock vehicles, I would assume it shouuld match a soarer, 300zx, probably not a supra?
Edited by vault13
https://www.sau.com.au/forums/topic/181963-whatll-it-do-200rw-33/
What other mods?
An R33 with fuel pump, cooler, turbo back exhaust, button clutch and standard ECU making 205rwkw ran a 13.1 on street tires.
LTHLRB I think where his plates.
Depends on the driver, depends on your tires etc..
There are a million different variables that could effect that time.
Edited by abu
http://www.importdriver.com.au/Coupe_Targa.htm
if this chart is incorrect, apologies in advance. (the prices are way off, the web page is a little old, but the other figures seem fairly accurate)
EDIT - plus i believe these times are based on jap spec 100 RON fuel
Edited by into oblivion
Ok assuming all the related mods
pump
fmic
boost control
turbo back zorst
clutch
safc or tuned ecu
street tires
no pfc or injectors just stock turbo, no suspension mods
Hmmm so according to the times into oblivion posted, this should trounce a stock 300zx in the 1/4 and come pretty close to stock 33 GTR, probably not 32.
What about 0-100 time, anyone know?
What other mods?
Edited by vault13
200kw doing a 12.8 on street tyres???
my run was almost perfect......seen as i can only get 0.1 closer using drag radials.....had a 60ft of 2.025 and 105mph
the car is stock except those listed as i did them myself and bought it completely stock....had 144kw when i first got it.....
thats some super skyline you got, i havent heard of anyone else making 200rwkw with a stock ecu
^^ mine's running 202rwkw @11psi. only mods are zorst, pod, intercooler, manual boost controller. was running 188rwkw on standard boost. i've seen a few other people pushin 200 with standard ecu,so it does happen
haven't taken her down the 1/4 yet though sorry vault13
i guess 2rismo has some expeirence in that area.. as in at the drags..
so im sure he would have mastered it.. if he did 12.80
i did 14 flat, with just full exhaust and no other mods (18s on front lol.. 17 rears.. 18s werent mine.. was borrowin rims, as mine had no thread on front)
Edited by siddr20
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
