A few sugar babys didnt front. specially in the afternoon session. Just threw the track open at the end and they lapped at their leisure.
Only had to assist 3 cars all day which wasnt bad given how wet it was this morning.
One rotor blew a snail and 2 others in the gravel. A darn good day really.
https://www.sau.com.au/forums/topic/181994-helmets/#findComment-3306033
would have liked a dry track, very fun though :P
that's it for track days from me for a while. will be doing a september motorkhana day, and possibly squeeze in the timeattack in october, then it's off for cams licensing and to try out a few other events.
https://www.sau.com.au/forums/topic/181994-helmets/#findComment-3306086
so, noel, how many black flags did u give out? :rolleyes:
nah they didnt trust me with the flags. somethin to do with being too old and blind or some shit.
I did recovery, got to fang the R36.5 prototype skyline around and drag the punters out of the kitty litter.
A tip for noobs, if you dont want your front bar ripped off make sure you have an accessible tow hook.
https://www.sau.com.au/forums/topic/181994-helmets/#findComment-3306134
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
