Didn't look too hard, mine was hiding near the dummy grid whilst I watched a couple of races whilst the skidpan group were on lunch :P
Hey Ben,
yeah, couldn't do much walking with the 3 yr old so didn't have a good look. Went down to the skip pan for a while, and his eyes lit up with all the round tailights:-)
  • Replies 56
I am not too worried about paying for a tow vehicle and trailer cos i was wanting something to tow trailers as well as an every day vehicle to drive to work. I am thinking of getting a 4wd ute or something to tow with and also carry the motorbike around in.
I was thinking of spending like $10k any ways on a good tow vehicle. I will worry bout the trailer later. I figured that i might be able to just hire a trailer from the local servo when i do need to take the car somewhere. Then when i can afford it i will buy my own trailer.
  • 5 months later...
lol bump for this thread.
RTA just sent me the renewal on the rally car.
not only do I have to fill in and send back a form to say the car is roadworthy (no inspection), but the bloody rego fee changed again. $54 including greenslip for the year.
Hahah bollocksn hell, this is what i wanted to do, was thinking of importing a new 32 gtr, putting all the good shit off my current car onto the race only and then sell the regesterable one. But thats for a later date now i guess..
the rally rego sounds good, do you have to actually compete in events tho?
:turned:
well it would be a big waste of time if you didn't. considering an NC licence costs about $500 a year (cancles out the rego saving if you are purely doing this to avoid regular rego) and you cannot just drive the car around whenver you please. you can only use it for specified journeys. like to the workshop, to the track, etc. not "to the rocks for laps" or "to meet up at liverpool maccs". so unless you are competing competition rego is a waste.
actually the NR license is only $190. I think its a real good option since even if you only use it for club days, you can
import it without compliance. save say $4k
drive it to mechanics
drive it to events
and it only cost $54 per year.
justbe careful with rental trailers, every one I've ever seen has been a swaying, crap tyred death trap.
the only sensible thing to do with a trailer is buy a new one. second hand ones all suck too. we paid $2k for ours second hand and then another $2k fixing it after. Not to mention $1k in good rims and properly rated tyres (came with retreads which killed themselves pretty regularly).
How do you organise driving the vehicle to/from mechanics etc. Do you have to ring anyone? Do they ring your mechanic/whomever to confirm you have a booking etc or?
ie can I just jump in my race/rally rego'd car and drive to wsid on a wednesday night or do I have to ring up 3mths in advance and get approval from someone?
you ring a 1900 number each day before you use the car and go thru a set of questions. no further proof etc required. I do get pulled up a bit and the cops never know what the rules ares - so I always carry all the paperwork with me.
sorry I wasn't clear. It is a recorded service you give them name,cams license, rego, purpose,date etc then write down a 4 digit permit number. no actual person.
They define it as "competition, practice and mechanical service" which covers everything you said and anything I've ever wanted to drive it for. Perfect option I reckon, especially now I know how easy and cheap rego renewal is.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
