Skyline newbie here again, i saw a r32 gts-4 for sale today and it got my attention. i understand that they are rb20 powered and all wheel drive. i would like to know how many parts they share with the GTR or are they literally a 4wd GTST?
https://www.sau.com.au/forums/topic/182206-r32-gts-4/
Well, as a current owner of one, I thought I'd comment:
The R32 GTS-4 is a great machine, but it's a compromise.
It has the GTR suspension, AWD, and can be modded to use the same calipers (from what I understand anyway)
apart from that it's really a GTS-T.
I chose a GTS-4 due to the fact that I love AWD, but didn't want the upkeep of a GTR.
You can easily install a 2WD switch, but the added weight of the AWD system mean it will not be as fast on the quarter mile as a GTS-T, but it'll kill it in the twisties.
The GTR will naturally own the gts-4, but then again, it's double the price.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3308932
all the running gear is the same as the GTR as far as i know.
just the motor/gearbox is rb20 spec.
definitely not a 'mini godzilla' though.
Yeah I think the GTS-4's gearbox has shorter gears for better acceleration. I think GTR owners who are into drag racing often put the GTS-4 boxes in because they're better suited to quarter mile.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3309002
No, the DIFFS are shorter (4.375 vs GT-R's 4.111)
I call it a "baby Godzilla" - all that is missing is 600cc and a turbo! Many of the mechanicals are interchangeable with the GT-R.
But with a RB25DET ... now that's another story!
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3309629
yeah this is what i was thinking , half the price of a gtr, a bit lighter, understated styling and lower geared. chuck in a boosted 25 and we're laughing
I guess 1450kg is a "bit" lighter than the GTR's 1460kg
I've had one.
unless it has something other than an RB20 in it, don't bother.
just not enough torque to do anything right.
I knew that before buying it and had planned to build an RB30/25 for it..
things changed, I sold it.
Stag engines aren't that easy to come by.
No you can't just use an RB25 out of any R33/34 skyline.
You can use an RB26 no worries.
but then after you've spent minimum $4K for engine and another $2K for the install and getting it running, you now have a car that is the same price as a GTR of the same vintage would have been and still NO GTR.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3310628
yeah i guess your right, im just trying to think outside the box. ;), i have seen a few stagea cuts forsale latley. im very suprised that they are similar weight to the gtr , they are very heavy for a small car. to heavy for a twenty for sure
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311564
Are you from America? How can you call a Stagea a "small car" ;)
Anyway, you also mentioned looking for a Stagea engine..... unless I am mistaken they have an rb25det just like an r33 gts-t? What is the difference?
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311610
i think hes talking about the gts4 being heavy for a small car.
the stageas are 4wd drive i think? the rb25 in them would have the front drive shafts/sump that would suit the gts4s. an rb25 from an r33 would need a modified sump and bits to go with it. that what i *think* at least.
i own a gts4, also. good car. great in the wet. sure not the quickest, but like the dude up top said its a compromise. even then, its fine to drive daily and unless youre really looking to have a race every set of lights does it really matter being that much slower? i like my 4wd.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311627
Stagea 4WD
Engine swap
Thought that was pretty simple to understand?
Either way i love my GTS4 and dont plan on doing an RB25 or 26 swap at all... Too in love with my RB20!
Should be making about 250-260rwkw soon and im really looking forward to seeing what the car can do then!
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311632
Stagea 4WD
Engine swap
ill tell you right now what it'll do. it'll munch right through your gearbox if its standard.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3311681
How many R32 GTS4 gearboxes have you broken?
RIPZ in NZ have these cars in the 10's using rb30/25 and stock gearbox and diffs.
that requires ALOT more power than 260rwkw.
and alot more torque than 4 rb20's put together.
they are not like a GTST rb20 gearbox.
https://www.sau.com.au/forums/topic/182206-r32-gts-4/#findComment-3313305
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
