well this is my car, i only spoted this section, i dint realise ther were so many 4doors around!!
OWNER
Darren
YEAR/MAKE/MODEL
1993 Nissan Skyline GTS25-T Sedan
ENGINE HARDWARE
Nissan RB25DET Twin Cam Turbocharged 2.5 In-line 6
ENGINE ACCESSORIES
Pod atm
intercooler is sitting in my house awaiting pipes
3" straight thru exhuast w/high flow cat and 4"cannon all madrel bent piping
DRIVETRAIN HARDWARE
Nissan 4speed auto (sadly)
BRAKES & SUSPENSION
Front: stock
Rear: stock
Stock Suspension all round
ROLLING STOCK
Stock 16"alloys
various diff rubber all the time
BODYWORK
Nissan Bluebird blue/grey apparently called "ice green"
INTERIOR
Stock Interior
painted dash componants same colour as car
STEREO COMPONENTS
Pioneer CD Player with Ipod adaptor
VDO 6" SPLITS
6" rear speaker
2x12" subs
2 amps.
PERFORMANCE
Standard i guess
FUTURE PLANS
Install coolerdone
Bodykit maybe?
steering wheel
seats
start putting in some tuning gear, ecu etc
https://www.sau.com.au/forums/topic/182210-my-four-door-whore-r33/
  • 4 weeks later...
finally put my cooler on after like a month of it lying beside my bed doin nothing.
Decided to do it the easy way and use the origional holes, makes sense rather that having the pipe
full of cold air running into my engine goin over the radiator and heating up its below the cooler stayin cold.
Intercooler $200 bar and plate
Pipes (2.5") $90 with a meter straight run left over, bent by zhaust shop.
Rubber hose and clamps around $120 i think. bunnings and supercheap
6hrs of labour with the misses brother helping- FREE!
tools used-me and alan. lol
took these pics last nite, have since driven it and need to ajust the 180 degree pipe as going over bumps it
gets squashed into the tow hook-solution:- cut off tow hook.
p.s would like to say a big bye bye to my reo bar, sorry to see u gone mwah xxx (lol)
piss off mark lol its OK alrite? not a beast yet but im workin on it. Had 2 ajust the pipes last nite, ripped em off on my driveway, was glad i had about a meter and a half of pipe left over, i cut up and used that. handy. there alil higher no so dnt scrape as much.
yea its standard, very rare tho, was on the spotted thread talking to a guy with a 2 door the same colour. ive only seen max 7 cars with this paint,(a 4door,2door,mine,a bluebird and a jaguar.) its stated as blue/grey on my rego sticker but a few people have said its "ice green" that sounds better lol) id have to repipe the intercooler the regular way before i cud lower this on coilovers (im thinkin of doin this as speed bumps and my drive way are giving me the shits now) and as for the deep dishes i dunno, the way i go thru tire atm im better sticking to stockos at $50 a tire it cant be beaten rather than forking out for 18 inchers all the time.
  • 1 month later...
Nice looking car Darren, i have the same colour on my four door r33, I've seen one the same in my area too, that and another green and grey one, which doesnt look as good in my opinion.
Im with you about sticking to stock rims, cheap tyres all the way
Im looking at doing a front mount like you have the pictures of. Do you think the front bar restricts the airflow much? because looking at our cars there doesnt seem to be that much room for the air to get in. Oh and kudos for the plates
Jez
  • 3 weeks later...
Jez
yes i think it restricts airflow but not now!!! see pics below!!!
thanks for the plate comments, i love them sooo much! my misses had the biggest nag wen i told her what i wanted to get she was like "get something about u incase u sell the car" (her names sally and her plates are 45ALY, go figure) but im like nahhh, the plates will go with the car wherever it goes, it deserves them took me ages to think them up!!
ps- big thanks to GTR-Geoff from sauqld for the donor bumper below!!(sorry i chopped it up!)
no.1 before
no.2 after
o and yes i have btw since repiped the cooler using a proper piping kit, i regret my first decision-diy piping kit bent by exhaust shop-noooo bingo.
ended up payin twice as much as i needed to but learnt BIG LESSON, do it right the 1st time lol.
also now have a spare, brand new cooler sitting at home if ne one wants to buy it.....
nah i was guna chop the fins off but they add a lil character, gettin an m-spec bumper soon neways so this one will be put aside along wit the stocko aswell.it aint too flimsy either, i thot it wud be thats y i left the original one alone so if i wrecked this one i cud put mine back on but yea im reinforcing it a lil 2day but its actually not too bad atm
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
