Hey guys, I am new to these forums, mainly do subaru stuff. But I have a question which is mainly aimed at all the guys out there using power fc's. I have one for my car, liberty rs, and I am running a Z32 afm at the moment. But I was wondering if you were able to elimate the use of the AFM with the PFC? I know that there was a special kind of PFC that was made, that didn't use an AFM, but pretty sure they were only made for a skyline, no subaru's.
But my question is, are you able to use a Air flow Converter, or Super air flow converter in conjuction with the PFC to get rid of the AFM?
Thanks in advance,
Mitch
https://www.sau.com.au/forums/topic/182243-running-no-afm/
You still need to have a signal coming in to bend. Where are you going to get you air flow reference from then? Why have a signal bender if you have a programmable ecu?
Need afm for normal pfc. Not need one for d-jetro.
If you search there is craploads of info on this topic.
james.
https://www.sau.com.au/forums/topic/182243-running-no-afm/#findComment-3308869
^^ As he said you will still need a signal to tell the pfc how much air is coming to the engine, the AFC and the PFC are only piggy back computers as where the PFC is a stand alone ecu so running a PFC and SAFC will only interfere with each other
https://www.sau.com.au/forums/topic/182243-running-no-afm/#findComment-3309016
you could run an safc and powerfc if you wanted but it wont achieve much
the safc wont allow you to ditch the afm to run a map sensor
have a look for the hks vein pressure converter, see if you can get that for your car
https://www.sau.com.au/forums/topic/182243-running-no-afm/#findComment-3309387
Thanks for the imput guys, will look into this pressure converter, thanks!
https://www.sau.com.au/forums/topic/182243-running-no-afm/#findComment-3310822
can you run two afms. i think with a safc you can have two inputs and convert it to one output then feed that signal into the pfc. or is the powerfc able to do this conversion aswell.
Edited by QWK32
https://www.sau.com.au/forums/topic/182243-running-no-afm/#findComment-3319206
yeah you need the safc to run two afms on a single AFM powerfc (or stock ecu conincedently)
https://www.sau.com.au/forums/topic/182243-running-no-afm/#findComment-3320912
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 馃槅 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 馃檪 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
