  • Replies 241
Posted Images
Date: 30th September 2007
Meeting Point: Near Glenelg @ around 11:30 for a 11:45 departure and Near Tee Tree Plaza @ 12:30 12:45 dept.
i'm confused, meeting in Glenelg then going to TTP??
anywayz i'm in, and mostly likely be tagging along with you (if that's ok)
and if it is i'll have to ask you something :P
hmmm need to ask me if an extra can come along :P
hahaha that would be what i was gonna ask :)
damn mind readers hahaha.
the extra person would be Reg, i told him if an SAU event or cruise
come up i'd see if he could come, and coz it's a Sunday it's the only
day he has off work and yeah haha
lol its ok i just realized that it is September not August ( how embarrassing ) at this stage i will be in Melbourne for the final round of the Intermarque Series, that depends on work screwing me over with time off ect
so i'm a maybe
oh btw guy dont want to be rude but please dont invite friends with lasers
i got no Problems with Shanon and her 200sx coming and other Nissan import turbos and well use discretion :(:P
I hope that funny looking guy with the 180sx isnt coming...whats his name? Barricade I think.. :P
Edited by ISC-Performance
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
