  • Replies 71
Thanks Bayley:D
Phuck you Macka;)
I've had a very busy few days so far.
Arrived at 5:30am, got picked up by my cousin, then a drive to Cambridgeshire. Had a couple pints of Ale, warm flat beer :spew:, and a roast lamb lunch at 2pm:D
Today I went into London and visited alot of the usual tourist places:D Saw Big Ben, Buckinham Palace, Hyde Park, Westminster, House of Parliament, Harrods etc:D
The girls would love Knightsbridge, full of designer shops that are way too expensive:D
Went on the London Eye, the big wheel thing, and got great views of London:D
More sightseeing tommorow, then on Wednesday I'm heading further up north.
Speak to you all soon:D
Have fun big Mack:D
I'll be leaving tommorow to head up to Scotland, meeting my cousin in Edinburgh, and were going into the Scotish highlands for a couple days, so I won't be able to be on the forums:(
I'll fill you in on the details when I return to civilisation:D
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
