Hi
I missed out on Sydneykids kit but he was good enough to refund the money
Bit of a mix up with courier arriving and me away. Wife too.
Hope to get some of his other gear later.
Sydneykid has some great posts
Ike
Edited by ike
https://www.sau.com.au/forums/topic/182581-sydneykid/#findComment-3338224
after selling us shit engines..maybe he doesn't wnan show his face ne more.
Did you ever recieve or go ahead with the engine? I remember hearing/seeing you saying something about wanting an engine, but it took ages to get done (could've been someone else).
You say 'shit engines' so I assume you got it?
Sydneykid has contributed heaps to this site.
https://www.sau.com.au/forums/topic/182581-sydneykid/#findComment-3352226
yeah Felix got dicked with his engine, 1 year wait then POS :)
http://www.gtr.co.uk/forum/upload/80137-r3...html#post721920"]RB30 SydneyKid build for Felix://http://www.gtr.co.uk/forum/upload/8...build for Felix
Infact Felix paid $8000AUD, he could've converted that to NZD last year and go just over $10k :action-smiley-069:
which is the starting rate for a RIPS forged package :S
RB30 Bare forged bottom ends (short block), start at NZD$10,450 (suit minimum 750hp and 8000 rpm) Ripsltd.co.nz
oh well, you live and learn, could've paid a bit extra and gone to RIPS for an RB30, as for suspension and brakes and other things SydneyKid definitely knows what he is doing, I can definitely see why Felix is pretty pissed, that's a lot of money :S
Edited by skybarge
https://www.sau.com.au/forums/topic/182581-sydneykid/#findComment-3353214
yeah Felix got dicked with his engine, 1 year wait then POS :yucky:
http://www.gtr.co.uk/forum/upload/80137-r3...html#post721920"]RB30 SydneyKid build for Felix://http://www.gtr.co.uk/forum/upload/8...build for Felix://http://www.gtr.co.uk/forum/upload/8...build for Felix
Infact Felix paid $8000AUD, he could've converted that to NZD last year and go just over $10k :)
Damn that sucks!
Thats a lot of money.. Sorry to hear man.
https://www.sau.com.au/forums/topic/182581-sydneykid/#findComment-3353359
Infact Felix paid $8000AUD, he could've converted that to NZD last year and go just over $10k :rofl:
:P That's a lot of money.
https://www.sau.com.au/forums/topic/182581-sydneykid/#findComment-3354630
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
