Hi,
Im finding a GTR 32 hard to come by, well a decent one that is. Does any one know of any for sale? a mate of a mate or a friend of a friend?
Have been looking at tradingpost.com and carsales.com, any others i should check out?
Plz point me in any direction.
Thanks
https://www.sau.com.au/forums/topic/182607-trying-to-find-a-gtr-32-in-adelaide/
Hey mate, When I bought mine I looked on carsales. From memory there was a massive amount something like 40-50 R32 GTR's through out OZ for sale. If theres not one decent one out of all those then your best bet is to import one yourself. Also if its imported under the 15yo rule dont buy it interstate as it will end up costing you more then you think, basically has to be re-complied again.
Ryan
Ryan
had a look at brads, nice for sure...
not reali interested in importing, dont want the hassel.
Wasnt Shrub32 selling his?
http://www.skylinesaustralia.com/forums/in...p;#entry3215608
Suprised hes having trouble selling it!
i hear that :laughing-smiley-014: had a couple of offers also a few trades one was for a gtir plus cash
I'd say the ones wanting 20+ are the ones worth looking at, especially if they're as clean and well done like shrub32's. Last thing you want is a rebuilder's dream...
lol true but who evers i decide on i wil buy on the condition it can be booked into boostworx first for a full going over
I would sell mine for $27,000 . Its a 94 (built somewhere in the last 200 to come off the production line) which I brought over 4yrs ago. Cost me $35,000 back then and have all receipts (over $40,000 spent) . Its silver and looks stock except for the exhaust and front mount. Last dyno at peter hall was 292rwks and compresion was perfect for all six cylinders. R32GTR plates with the car. If your interested pm me , And i will list the mods. Insured for agreed value of $27,500 with H2P.
I will cry if you do buy it though so bring some tissues for me.
Also thinking of selling mine. It's an '89 with a few mods. Need cash more than a car sitting in the garage. Probably only looking for around $17 K mark.
If you are looking for a perfect GT-R this may not be for you, but if you want an honest and registered car please PM me.
Cheers
$40k spent and only 292rwkw?
rather little for the money imo
Dollars spent not just on power obviously.
This car looks stock except for the exhaust and front mount as said but this was my daily driver for three years.
I will give you an Idea where the money has gone
front mount high flow (tilbrooks special) $1800
HKS piping for above $600
custom manifolds $1200
R34 N1 turbos approx $6,000 (runing 1.1bar )
custom 3 1/2" exhaust from dump pipes back inc high flow cat $2,300
Carbon cannon muffler $500
exedy twin plate clutch (replaced twice) first 1 cost $4thou and got smart 2nd cost $3thou
custom bushes for rear cradle suspension $600
offset bushes for entire front suspension $1200 including labour
replaced engine mounts $250
airflow meters replaced twice at $350 each plus dyno
ignighter coil
power fc plus tune $1550
new fuel pump
new N1 water pump
new air filters $200 (plus purchased stock box $160 plus new filter $200)
alarm $600
alpine deck(cd) $400
new focal speakers $600
timing belt done $1000
timing belt tensioners done twice(included above) and another $400
gold dba cross drilled rotars front and back with pads $2,200
theres more but minds gone blank
the last bill was $3,800 (clutch $2,500 labour $500 , service injectors $200, new calcium battery $120, replace gear box oil $90 (inc flush) clutch hose $120 , rekit clutch master cylinder plus service.
These cars arent cheap to run LOL
The turbos are not for big KWS but for optimal response.
The only things needed are boost controler and larger injectors (fuel system) and more power.
The old parts are sitting in the shed (intercooler , dump pipes, turbos etc)
easy to spend $40,000 LOL
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
