ok im running an rb26 with an rb20 trans
my stock rb26 flywheel has sufrace cracks all over it and a shit load of heat spots onit! are there any other options i can go with besides getting a flywheel for an rb26? does any of these work?:
rb25det
rb20det
z32 vg30de
z32 vg30dett
im going to use the z32 vg30de na clutch for my motor but what flywheel will work for this setup?
thanks
https://www.sau.com.au/forums/topic/182614-need-flywheel-options/
rb25det
rb20det
z32 vg30de
z32 vg30dett
thanks
i have an rb20 flywheel and a rb25 clutch and gearbox on my 26 so im almost sure u can go rb 20 or 25 flywheel i picked up flywheel and clutch for $50 from wreckers just dont tell them is for a 26 or they will charge u more.
Greetings,
I used a VL commodore flywheel on my r32 skyline w/ rb20det conversion..
Mine doesnt have a locating dowel in the back of the crank, nor a hole for it in the flywheel.
After 15k of abuse w/ my daiken exceedy HD clutch.. still kicking 3rd gear no problems...
  • 2 months later...
ive read in another forum that if i want to use a GTR clutch, i must use an RB20 flywheel along with the RB26 clutch disc and pressure plate with my RB20 transmission,. is this true?
ive got an RB26 flywheel, RB26 clutch disc, and RB26 pressure plate, and im not sure what combination would work for my GTS-T since someone on another forum said that the RB26 flywheel wont work if im using an RB20 transmission
  • 1 year later...
