Another full field of entries for Round 2 of the Toyo NSW Drift Series this Saturday at Oran Park.
Eugene Arendsen
Chris Easton
Jason Greenwood
Josh James
Chris Jones
Andrew MacGregor
Sam Pass
Brett Reid
J.J Screpis
Michael Truscott
Nathan Weissel
Anthony Bilic
Ben Ellis
Kirk Gyford
Ashley James
Brendon Keenan
Daniel Mackie
Stephen Pembrey
Matthew Salim
Tim Sorrasson
Igor Tunjic
Dion Yandle
Nathan D'Avoine
Scott Gibbs
Martin Jagodzki
Mitchell Jeffery
Mike Laverick
Marcus Newark
Matthew Porter
Alex Sciacca
William Thompson
Eiji Wakamatsu
https://www.sau.com.au/forums/topic/182672-toyo-nsw-drift-series-this-saturday/
damn.i would but have somthing else to go to allready.i was at the IDA track day last weekend though reprazenting on the hill watching from the car.it is allot better if you can just laze arround in the car and veiw.just like home :D
i seen dan makie out there and Fernando Wiehrl.there is some pretty good local talent out there as well.also quite a few crashes with pretty big damage.
hahaha great post Druncan :):D
Go Dan and Easto!
oh, Easto's entry's - fark me - MASSSSIVE!!
I was behind him going around OP North at Driftland and it was just amazing!
Yes true however when you go from an event like at Eastern Creek with a few thousand people, trade displays, car show, stunt riders etc to a dirt paddock at Oran Park Driftland it's quite disappointing from a spectators point of view.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
