yep! looks awsome. The suns reflection off our atmosphere boucing to the moon give it the real deep orange effect. (like a sunrise on earth)
can happen twice a year...so they say......
Edited by boostd_r32_gurl
https://www.sau.com.au/forums/topic/182695-lunar-eclipse/#findComment-3314607
Here's a couple pics I took. Only got a 7x optical zoom so its not brilliant but does give you the idea...
The photo was taken using a tripod and 8 second exposure. focus set to infinity.
Turned out better than I thought it would :)
Edited by pixel8r
https://www.sau.com.au/forums/topic/182695-lunar-eclipse/#findComment-3314680
Great pic......
This is the first time i have seen it this orange in years.... the last couple have had cloud cover when its happened
Ive spent the last hour or so with the telescope looking around..... Jupiter is looking good tonight too.... i can see its moons!
https://www.sau.com.au/forums/topic/182695-lunar-eclipse/#findComment-3314723
Luke n I went to Mt Lofty to see it, fair few people up there and lots on side of the road on way up. Looked pretty cool, listened to radio on way back, they were saying out south or on the beach wouldve been a good spot.
Either way looked pretty cool where we were, could even see it from my house pretty well and im right near the city.
https://www.sau.com.au/forums/topic/182695-lunar-eclipse/#findComment-3314844
The best place to see the eclipse was out my way they were saying. (gawler) It happens every seven years.
Its commonly refered to as a blood moon. Isaw it back in 2000 and was just as clear as it was tonight.
Its incredible how fast the eclipse takes place. Was watching it in the GTR on the way home from work (sitting at the traffic lights that is ) Amazing! :)
https://www.sau.com.au/forums/topic/182695-lunar-eclipse/#findComment-3314877
theres a guy on gamearena that normally takes killer photos but couldnt find anything he took this was the best i could come up with and its not his work
what camera did you buy :)
Edited by Madaz
https://www.sau.com.au/forums/topic/182695-lunar-eclipse/#findComment-3315007
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
