Im trying to get hold of some RS-Turbo stickers for the side of my DR30.
So far I found some on the Jenesis webstie www.r30.co.jp but cos i cant understand Japanese I havnt had any luck ordering any. I tried emailing them a couple of months back but never got a reply.
can anyone help me out?? Is there any site in English preferably Australia / South Australia.
I have allready tried JMS, Jaustech, Adelaide Jap imports to no avail.
also does anyone have the paint code for the bottom 1/2 of the car, mine was painted black in the respray, I hear its really ment to be a real dark metalic blue.
cheers
-Glenn
https://www.sau.com.au/forums/topic/183007-dr-30-rs-turbo-stickers-for-side/
Make your own. Any sign maker can do this. Take a picture of the signs you want or a scan from what you have from Jenesis and get them to make it.
As for colour coding if your car is red, it's 013. If it's 2 tone the only factory reds were 059, made up with 013 Red over 028 Grey and otherwise 013 Red over 826 Black, according to my JDM Brochures.
Do you have a colour code on the compliance/manufacturing plates?
I took some high-res photos of my decals for ChokudoriDR30 last year, if you decide to go the signmaker route I'll see if I can dig them up for you.
Jenesis are rather iffy about sending stuff overseas. Not sure if it's the language barrier or what.
Its White over black atm.... Car came all white from the Factory so doubt it would have any colour codes on the plates. heard from a few people it should be a real dark metalic blue for the white ones not black? so thats what I came to beleive.
looks like I might have to go that option. if you can find them it would be sweet.
PM me if you're set on getting the Jenisis ones I know a dood who can prob hook you up.
And yes my Iron mask coupe was metallic blue on the bottom 1/2... maybe an affect of fading with age, but it def wasn't black.
Will see how it goes, If its gonna be abit of a headf**k with Genesis I guess I would only be looking @ them there If i decide on buying the 260kph gauge aswell. bonus is it would go from 85,000kms to 0kms ;)
cheers
-Glenn
Glenn..
Your right, the car was all white to start with, Crimmo had it sprayed white or black
The black isnt black, its black with a blue pearl through it! I could probably get my paint codes from mine as mine was white over black from factory!
Have you tried Datsport?? I enquired about some down there before and they said they could probably get them, worth a try!
Nah I havnt, a guy I spoke to with a couple of DR30's awhile back said he tried that option but no luck.
Ended up going through an SAU board member Taran....... Apex Graphics - http://www.apexgfx.com
im just eagarly awaiting them now :blink:
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
