  • Replies 98
Posted Images
wtf, i did 1 just b4 this and it told me like 3.5 or something, and i thought, thats not right.... so i did it again and got that
oh and thats with iinet
adsl 2 i think?
Edited by Dearlove
Wow, some of you guys have really slow connections. I hope you're not paying too much!! Excluding the people who are testing their work/uni connections I think I'm the fastest thus far?
My home connection
TPG ADSL2+ $70 for 150GB / month via wireless, old plan should upgrade.
EDIT: Will, what connection is that? Your upload is > 1mbps!
BTW, This is UQ
You guys do know that speedtest.net is only supposed to be used as a comparison tool to measure how your line speed was from 1 day to another? It's not used as an industry standard of line testing because it all comes down to location of the server you are doing the test from. You might set it as adelaide and be in perth, however get a faster download speed than if you had of chosen the perth server, because the content server might not be located where you are doing the test from. Not only that but you don't know how many hops it is to the download server from where you are aswel. Only way to really test it is to find a local server, say for instance if you are with iinet, go to ftp.iinet.net.au and download the adsl2.test file and see what your average download speed is from there.
  • 4 weeks later...
  • 7 months later...
  • 7 months later...
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
