  • Replies 60
nothing.. honest, I was coming back from Maccas Golden Grove about 10pm for a late night mcflurry binge and a cop pulled out from the golden way and followed me for about 4 mins then flashed the lights so i hopped out of the car looking scum and yeah he just gave me a warning saying the car looks too low and the boost gauge is a defect etc...i just played dumb.
In 2 1/2 years i've been pulled over 2 times, been thru a defect station once and cops pulled up while parked and went over the car as well as a mates 32 and S13, and never been defected(touching wood right now) but not saying you "have" to be doing stupid shite, but just drive sensibly and you'll be best off!
+1 cubes Salisbury need we say any more (BTW im not being prejudiced towards Salisbury i used to live there and know full well SOME of the ferrals that live there and illegal behavior that goes on)
*jaw drops*.
Last time I got pulled over in that car was about 12 months ago for a breath test. :thumbsup:
Edited by rwieczor
Ahhhh yeah..... too much information....
2 1/2 years driving the skyline... never been pulled over...... :sorcerer:
Edited by Mr Sniper911
i love this car so much, but the first night i drove i got pulled over by the cops. which sucks, the cop was ok about everything and let me off with a warning,
tell you what! first day i got mine i got sent to regency for being too loud! and i was just cleaning the car
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
