yeah i know it was a joke, mine was just a little payback :)
that is actually not my car, its another simons garrett t04z with 0.84 rear stock capacity rb26, stock plenum and throttle boddies...
my car isnt making that much power yet because of a faulty trust bov leaking my boost, but went a very easy 420kw with problem. will be getting mine tuned again soon on some more boost (hopefully not escaping out the bov this time) and see how she goes but looking like it will be very similiar to this one
  • Replies 682
T04Z's are a great turbo aren't they...i was almost going to go that route with ours. The torque curve on that graph is testament to their ability. But getting a little common now and we wanted to think outside the square as per usual. When i say "big single" im more refering to the T88, T51R, GT42 and GT45 brigade. The T04Z is more of a mid-range all rounder, and allows the owner a bit more flexibility with the usage of the car, street, circuit, drag etc. They also had the added feature of easily altering the rear housing to suit each application which is another plus for them.
hehe she's pretty mad (you wont see a torque curve like that with your big single)
ive love to give you a drive steve but that would be unfair to your underwear...lol
its an OS Giken 5 speed.
Hehehe
Would love to go for a ride in it (ill even wear a second pair of underwear for that :) )
Ill do my best to come see it at WSID ;)
yeah mine (t04z 0.84) seems to fit what i need very well... mostly street, soon to be a little drag and circuit
considering the build of my engine, no head porting, stock plenum, valves and throttle bodies getting over 20psi boost at about 3800rpm in 4th gear and looking like it will make 450rwkw fairly easily you cant go wrong.
still when people using t88's seem to be making just over 500rwkw compared with nearly 470rwkw from a z but with more than 1500rpm more lag, it seems a bit pointless to me to go "the big single"
precisely
the last time we raced it weighed 1474kg...without the 106kg driver...so a 398KW GTR to go 10.3 sec's weighing 1580kg with a synchro box is a fair achievement.
we have stripped some weight out of it since so it will be interesting to put it on the scales at the track next week.
unfortunately i still weigh over 100kg
Yeah, for sure, those figures dont lie. Good hp.
100kg....I can race it for you ;) Im 60 :whistling:
3 Rotor + HKS T04Z + 10PSI = 350rwkw (with an auto) :whistling:
Turning boost up on Friday ;)
im sure your auto will make a meal of the strip...so dont be too concerned about dyno power loss with it...Brendan, properly tuned and set-up you have a 9sec car there.
congrats :rofl:
I saw your car there on saturday with my mate adrian (he had a bit of a chat to you in his pretty lil I.S shirt :thumbsup: ). Saw it on the dyno too, had a bit of a giggle about black smoke ending up on the show cars :D
Car sure came with the goods :P
congrats :rofl:
Yeah Jim had the tune really rich and a lot of unburnt fuel ended up out the exhaust pipe. A few "show" cars copped a bit of it...lol
350awkw @ 10psi on Saturday wasn't too shabby considering how rich it was.
seriously bushit power. one very eficant engine you got there. im clearly doing something wrong.....
376awkw on 1.6bar with t04z .84split rear. poncam 260/9.15 mild port job. (around the valve seat area) 90mm staight through exhaust. smc autronic 900cc injectors. should be making more??
Dave remember...the dyno is only a tuning tool...how does it feel on the road mate??
ours made the same power as before but the seat of the pants is telling me the cars are not even close to being alike.
am pushing thru massive amounts of exhaust with the 20B - and I have a 1.32 rear housing.
Sorry - thought you were referring to T04Z - compared to mine - ha ha
I reckon Paul is running a pretty funky compression ratio :D
haha tru tru. it feels the same but just fatter. goes alot better. still 375awkw aint bad. i think theres some power hiding in the valve lift or lack there of.
thats on the backburner now. as my route 6 gearset exploded.
Dropping the car off back at Croydon's tomm. for full tune and possibly fitting the Autronic ecu. If not fitting the Autronic ill run the car Wednesday night with the Power FC PRO fitted and use the two-step to get it off the line. Will be interesting to see what sort of numbers it will run. Ill be taking photo's/video's of dyno runs and drag runs too....stay tuned!
I went to the autosalon but i could not wait around all day for the best car at show to run so i missed out on the run.
Looks great and congrats on the win!!! Good to see a RB win a event :) woulda been different if Miss 2j ran... Anyone know what is up there? =)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
