i thought u said somewhere u had a t62 to go on it?
took ur time paul, fingers crossed for 8's when its ready :thumbsup:
just got home.. Yes Twoogle is alive once more! New engine sounds beutifull. :P this car.
  • Replies 682
took ur time paul, fingers crossed for 8's when its ready :D
well its a bit of a hybrid actually...HKST51R housings upgraded to T62 spec...108mm compressor. So it looks like a T51R but goes like a 62. 1200ps.
it means nothing...
our number plate reads TWO.06L...meaning two point six litre.
some people when making up custom plates use a 6 as a G
my mate one day was looking at the plate and asked us "what does twoogl mean"?
we had a laugh and explained to him that it meant 2.6litre...and that the 6 was not meant to be a G but actually a 6...
he said nah stuff it im now gonna call it "twoogle"
this name stuck and has grown to even been included in the drag records lists and in magazine articles
its weird how some nicknames evolve and stick
so thats how the car got stuck with such a silly nickname
Nice work cant w8 to see this best run down the strip. how much power you hoping to have in it now.
need 900hp at the treads to run the 8.90 im aiming for.
the turbo should provide the power...if not ill give it a spray. :D
Just found this thread today also. Twoogle was actually an inspiration to stick with the twins for my 32 and hence the GTR-S's on it now. you defo had the sort of torque i'll be looking for when mines finally finished. You ready to cough up those cam specs yet. :geek: haha. Still interested to see how you go with the T51r though.
My Friend and tuner that owns the workshop I use up here in townsville is building a 26/30 running a brand new HKS t51r spl thats going into a 180 sx so interested to see what sort of power can be made from the big singles.
Good luck Paul and keep the updates coming.
Just found this thread today also. Twoogle was actually an inspiration to stick with the twins for my 32 and hence the GTR-S's on it now. you defo had the sort of torque i'll be looking for when mines finally finished. You ready to cough up those cam specs yet. :) haha. Still interested to see how you go with the T51r though.
We got the torque curve even flatter with the final tune using Sonoco. The option to upgrade to this new set-up at no cost was too hard to pass up, but i will always be a fan of the twin low-mounts.
The cams we used on the low mount set-up were big JUN's... :geek:
Humm big JUNs. That helps....haha. Well I've bought a pair of tomei 10.25 lift 260s but i also have a 10.25, 270 exhaust to try as well. What do you reckon? On the right track at all to make these hks's work well?
what did the cam doctor say on them 272 11.35's?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
