Good work Paul, what class are you running in over there? seems odd to run 9 second cars against the big drag cars, they definately dont do that here, theres a class here for all the injected drag cars and they are running around the 7 second region and compete with altered's and small rails with small blocks. The handicap would of been huge, you would of been at 3/4 track before she even left the line lol :D
so does this mean the ppg "should" be pretty bulletproof now, or still possible issues with it? Are these shifters available for anyone or whats the go in getting one? I assume it can also be used on a circuit as well or only for drags?
Send me a PM regarding info if you can mate.
thanks
The first shifter was a custom job made from 4340 billet...we will be producing them as a self fitting upgrade.
you have pm
Edited by DiRTgarage
  • Replies 682
I want to see pictures of this new sexy shifter!!
here ya go...not much to see though. The white cable is the signal feed from the load sensors to the interface box (silver box with led's on side of console) the red button and black cable is to activate the anti-lag prior to launch. The shifter itself is custom made from 4340 billett and has 4 load sensors bonded to read in 4 different directions of movement. The sensors are then covered in epoxy and heat shink sleeve applied (black area under the gearknob) for durability.
Scared? The Dirtman ? lol!!
He will hit it when he is ready
ill not ever be running NOS in this car...as the Ignition DVD states "there's no need"
our goal is well within reach without it.
the cylinder pressures when running NOS on a high boost high rpm set-up hurt parts very easily.
it was installed a few years ago when i believed it was a necessity...nearly all the big drag GTR's don't use it and the power delivery is a bit too hit and miss for bracket racing unless its properly set-up.
Delay boxes arnt used on manual trans, had a few Jacks by that stage last night and forgot Pauls car wasnt converted to auto lol, but have a read of this anyhow
http://www.bullseyeracing.com.au/articles/...y_boxes_101.htm
Pussy.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
