Call ABS at Springwood, Dan (3lit3 32) works there and he knows his skylines!
Plus it is a place that specialises in clutches and brakes!
good to know i didnt realise thats where he was - just down the road from me!
Thanks for the input guys ! Much appreciated ! :P
Does anyone used this clutch before ? Any comment on it..
hahah em....your game thats all i can say, if you want to have fun and one calf bigger then the other.
for a street car, kinda silly.
i would look at a exedy heavy duty organic or heavy duty semi solid cushion ceramic centre.
orc apparently do some good ones too.
do you value your gearbox! :P
and the health of your neck!!
but as shane says...you could put a cup of concrete with it and harden the f**k up.
but we dont listen the shane.
www.option1garage.com.au
Give them a go...Heard good things.
very good blokes. :P
dans good. ABS deal with brakes and clutches for ther bread and butter why go anywher else.
apart from Jim Berry.?
haha harden up fellas.. nothing wrong with a stiff clutch..
and as if thats gonna shred a R34 box.
Thanks for the advice.. I was gona get ORC clutch ...but found out that ORC clutch are push type only for R34 and a conversion kit needed which i don't really wana drill some holes in my gear box..
do you value your gearbox! ;)
off course i do and i value my neck as well.... hahaha :laughing-smiley-014: i guess this clutch is not suitable for me then..
that's what i'm worry about.. :)
you wont break the gearbox through just having a hard clutch like you say, but if you drive it everyday and everywhere then the wear and tear on the clutch itself will ruin it. Button clutches arent designed for everyday driving, they fail under slipping forces.
for a track car there is nothing better then a button ceramic, but way better getting a heavy duty organic for road driving, or a twin plate organic, if you want something heavier.
basically.. for street when u need to ride the clutch occasionally. u want a full face organic. perhaps a ceramic. or multi.
for track with quick shifting and no need for riding and want to limit/eliminate slippage a button/puck or multi would do the trick..
i do like the exeddy HD full face organics. thats what i used in the RB sil and s14a uses one too.
but apparently ther is a difference between the HD aussie made and jap made. i like the feel of the jap one better
Give Brad at G&A mechanical a call hes in sumner park i get all the work done on my 32 done with him, and never had a problem. He put a HKS tripple plate into mine.
Cheers
ur signature gives u away. how much did u pay for it.?
Don't mean to hijack but couldn't justify making my own thread to ask this. Where should I get my FMIC installed (Brisbane - southside preferrably)? And how much would this cost?
I've also got an exhaust I want to get installed which I was going to get done at Right Price Exhausts (got my WRX exhaust done there and they did a good enough job / price). I'd consider getting it done at the same place as my FMIC though to save some dollars. Although - how hard would it be to do it myself? Worth doing to save the $$$?
Thanks.
Thanks.
You can DIY if you get the right FMIC.. or ask marki to give u a hand.. :laughing-smiley-014: depands on how much you wana spend.. PM me for details if you want more details .. what sort of car u got ?
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
