Spotted this at the warehouse at my work
Brand spaking new Aston Martin DBS.
It looks even better in real life. I wish i could've taken more pics but i wasn't even supposed to be in there but couldn't resist.
Edited by 4admrn
*Jizzed in my pants*
I keep spotting an Aston Martin DB9, and Bentley Continental around Norwest/Castle Hill.
yeah the Bentley is a woman driver?
She's the Degroot airess (you know the guy who rode in on a horse and slashed the ribbon with a sword instead of the queen when the harbour bridge was first opened?)
They live in West penno hillz yo
And their is 2 DB9's I keep seeing probably the same ones
Does the bentley have just numbers on the plates? Or it's personalised..i can't remember.
But last time i saw it, a guy was driving?
are you sure? only 1,315 were made, ferrari enthusiasts would kill to see at least one
100% mate, i'm a Ferrari fan, even if they are slower than the R35...
They were both yellow and within 1km of eachother
