What an angry angry engine, Finally got it to run after a hell of a lot of dicking around. Man i seriously felt like pushing it in to the back yard and parking it permanently. Thank god some young fellas have more patience than me.
Mick and shane plugged away while i went and sulked and before you know it its idling and it sounds like armagedon.
Wonder how many mufflers you can fit to a gtst.
Shane and i drove it round the block and all systems appear to be working, brakes are an issue. hard hard pedal and very average stopping power.
Hopefully it goes on the dyno tomorrow , Mick the magician can cast his spell on it and make it quiet as a church mouse with a gazillionty horsepower. :P
  • Replies 187
Posted Images
ahhhhh i just had a fat attack, i dont want to sell mine now.....i want to put the 25 in it.
That sounds farken stoopidly horny old man, shotgun a straight line run in it. i dont want to go round corners with you with that much power.
Just make sure you dont break it.
So what was the problem anyway?
Can it be told or?
Can it be told or?
Sure mate, No secrets here. It wasnt one problem as such but several very annoying stupid niggles.
Wrong injectors first, then a crook afm, then a dodgy signal wire from the afm to the puda, then a cas niggle. It was really starting to piss me off. On top of that the puda didnt recognise any of the engine settings till magic Mick tapped out several different sets of new numbers on the lappy and away it went.
It hasnt been tuned yet, but hopefully that will happen today. The numbers are all safe for me to at least mosey it around to the workshop and thats excactly what i will do shortly.
Sick!!
can i push the accelerator at some stage??? while stationary of course.
Its kewl dude, i've seen you drive remember. :thumbsup:
yeah true, did you still want to take a ride in mine to check the suspension?
just letting you know after talking with a few people, if mine doesnt come up to scratch i will prob be looking to put SK's gear in it. but if mines ok then it'll stay, but my ride height is gaying up my handling atm...which is kinda surprising how it will handle when it is set right.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
