3 Genuine Gibson Motorsport Hr31 Skylines At Sandown Raceway
3 Gibson Motorsport HR31s will be racing at Sandown Raceway November 9/10/11.
These cars are the real deal;
Jim Richards 1990 ATCC winning car in full Nissan warpaint (chassis #5)
Alf and Tim Grant's 'Sizzler' car (Chassis #3,Ex Mark Skaife)
Chassis #1 in original Nissan colours (Ex George Fury, Glenn Seton, Mark Skaife)
All 3 cars are as raced.
If you haven't heard the howl of a full race RB20, now is the time to educate yourselves!
And say hello to the charming and glamorous pit crew (1 of which is me)
Hooks
Usually 2 practice sessions on the friday, qualifying and race 1 on Saturday,
And race 2&3 on Sunday.
As for actual times, who knows.
Depends on whether we are the feature race or not.
Either early morning (9am) and early arvo (12;30-1;30)
Or late (10:30/11 and 3-4)
Hooks
this is the historics yes? They regularly run these in the historics along with a few other group A cars from that period. The Gibson R32 is also there but doesn't get raced, I have seen it being driven around though. You can usually go right up to it and poke the engine bay etc :).
Yeh, this is the weekend of the Sydney trip. This really sucks. The owner of the Vic GTS-R has finished his other liitle project which has been a big demand on his time. I suspect he will be racing his new toy rather then the R31...but will ask him next Wednesday when i see him
Good and bad news.
Bad- Terry has sold his HR31.
Good- he sold it to Chris (Sizzler car)
Bad- Chris may not be able to make it to Sandown
Good- Terry will be coming to Sandown
Bad- he won't be in the HR31
Good- he will be in the #1 Winfield GT-R
Bad- he won't be racing it
Good- Rod will be racing his HR31
Good- The GT-R will be on display.
Hooks
Hooks
Would you have any idea closer to the date when these cars might be out on the track?
  • 1 month later...
Seems only 1 X R31 is making the journey...but thats cool. There is still the Grp A Jag XJS, Tweedie in his Sierra and Vic's own Gavin Strongman making the first track return of the R32 GTR to the track!. There is the JPS M3 in there and John Bowes old Turbo Volvo 240...along with Commodores, Mustangs and the Group C crowd of Toranas :D
Plus, a friend is debuting his Group NC car this weekend, so should be big!
But, i fear unless the Nissan boys have a real go that the Mike Roddys' Jag is going to eat the field alive :) My poor RB20 :D
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
