  • Replies 57
Hey fellas i rang brant up and they told me that none of their alarms work in tandem with ANY turbo timers..
is this true? or has the guy bullshytted me??
ive got aHKS type 1..
also ppl that i spoken to..said that using a turbo timer..u gotta see how much the engine "shudders" when the timer turns off the car...cuz the engine shudder can cuase the "armed alarm" to be triggered and go off...
just a though
mc
:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36266
Err~!! take out my TT?? i havent even put it in yet..hehe
yeah prank the type1 has a 0-400 etc etc..but you wont be able to use the TT function..
DOes anyone know of any INSURANCE APPROVED alarms on the market that support turbo timer functions? for say :
under $600
2point immonbilisation.
black wiring
separate brain and siren?
pls help
mc:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36309
Originally posted by soopamarcus
WTF? are u kidding me? the tech guy at brant said they couldnt get it to work with and TT...
what turbo timer does ur friend have? and also which model brant does he have fitted?!~
mc:shake:
not sure - i think its an older model brant system...
i'll find out, but i know him well and i have seen it all work.
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36345
I got a TT and a Brant.
The deal is for some legal reason turbo timmers ain't legal so brant doesn't want anything to do with em.
What my car does is
You can look the doors and let the turbo timmer run then 30sec after the car turns off the imobiliser turns on but the alarm will not turn on unless you hit the button agian.
So it sorta works...
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36437
The Brant AA02 and Nemesis both work with turbo timers as I know a two people on this forum with this setup working fine.
Turbo timers are illegal though and if your insurance company finds you have one i have heaard they may not payout if your car gets flogged. Dunno how they can do this though....
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36503
