  • Replies 57
Hey fellas i rang brant up and they told me that none of their alarms work in tandem with ANY turbo timers..
is this true? or has the guy bullshytted me??
ive got aHKS type 1..
also ppl that i spoken to..said that using a turbo timer..u gotta see how much the engine "shudders" when the timer turns off the car...cuz the engine shudder can cuase the "armed alarm" to be triggered and go off...
just a though
mc
:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36266
Err~!! take out my TT?? i havent even put it in yet..hehe
yeah prank the type1 has a 0-400 etc etc..but you wont be able to use the TT function..
DOes anyone know of any INSURANCE APPROVED alarms on the market that support turbo timer functions? for say :
under $600
2point immonbilisation.
black wiring
separate brain and siren?
pls help
mc:shake:
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36309
Originally posted by soopamarcus
WTF? are u kidding me? the tech guy at brant said they couldnt get it to work with and TT...
what turbo timer does ur friend have? and also which model brant does he have fitted?!~
mc:shake:
not sure - i think its an older model brant system...
i'll find out, but i know him well and i have seen it all work.
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36345
I got a TT and a Brant.
The deal is for some legal reason turbo timmers ain't legal so brant doesn't want anything to do with em.
What my car does is
You can look the doors and let the turbo timmer run then 30sec after the car turns off the imobiliser turns on but the alarm will not turn on unless you hit the button agian.
So it sorta works...
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36437
The Brant AA02 and Nemesis both work with turbo timers as I know a two people on this forum with this setup working fine.
Turbo timers are illegal though and if your insurance company finds you have one i have heaard they may not payout if your car gets flogged. Dunno how they can do this though....
https://www.sau.com.au/forums/topic/1840-brant/page/2/#findComment-36503
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
