Hi!
I've been struggling to get my fuel cut running. RB20DET.
Motor was wired in a carb car. Car had a socket for nissan efi pump, but I didn't connect the wire from the ecu to fuel pump.
What I wanted to know is:
1)Will I regain fuel cut function if I get a wire from ecu to fuel pump relay ? So it will turn off fuel pump, hence fuel cut ?
Or if ecu turns of inj. for fuel cut, where do I look ? Inside the ecu for a modded chip ? LOL
Thanks!
Edited by robots
RB limiters cut fuel (probably injectors, easier for ECU to deal with) not ignition, if they cut ignition we'd have built in bee*r limiters :whistling:
Bingo!
As for cutting ignition rather than spark, I don't think its that easy. I remember reading about it and it either couldn't be done or was too hard or was more expensive than buying a Bee*R Limiter. Best to ring a ECU tuning place like Dr Drift ans asking.
Can someone confirm why they decided to cut fuel?
I mean, cutting fuel will definitely do more damage then cutting ignition? Excess ignition is usually what kills a motor not access fuel?
But there must be some logical explanation behind it, maybe simple as JIN_MAN said, its easier to cut fuel than ignition?
Bingo!
Why would it be so difficult? All it is is a piece of computer logic:
If <too many revs> then don't send a signal to injector.
Why would it be so hard to implement it as:
If <too many revs> then don't send a signal to spark.
As I said previously, too many WRX engines have melted pistons because Subaru chose to implement a fuel cut limiter.
I'm pretty sure its a fuel cut too, and I'm surprised to hear it could melt a piston.
When the ECU tells an injector to shut, the cylinder is not firing at all, its not running lean - so I don't see how it can melt a piston?
Anyway, it is simple to disable rev limit in the software of the standard computer, so the one you have might have had this done already. However without hooking up the mapping interface to fix it I don't know how else you could put it back.
When I said "As for cutting ignition rather than spark, I don't think its that easy." I was referring to an ECU tuner trying to chance the setting, such as Dr Drift.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
