lol its nothing crazy? i just deposited the money on friday and i bank with nab and it would of gone in straight away and im still marked as unpaid :S
im sure its just a mix up or something . ive sent a few pm's about 2 days ago got nothing back... im sure its all fine , but really want to get my status marked as Paid. for that track day.
Thanks Sam :)
Yeah Izzy ive just replied the to your PM, sorry but im a pretty busy person most of the time (eg im at work now but i stopped in a net cafe once i heard about this). Your spot will be ok, i dont know about instant bank transfers cause they usualy dont happen until the next day (as sam said), if you sent it yesterday im sure it will be there monday :)
EDIT: Even better than that, its appeared on todays sheet. Check your status now if you want, im going back to work
Thanks Sam :)
NOOIIICE!! thanks steve. sorry i was just a bit worried my spot would of gone to a paying member. and i just needed to know if i was in 100% cuz im going to the shop to get some tyres now :)
cheers n thanks!
-iz see you there
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
