I brought LED TAIL lights for my r32 GTR from JUST JAP in Kirrawee, SYDNEY. They dont fit on perfect! one side fits different to the other side and I CANT STAND IT. I played around with the lights so much that i eventually snapped the thread coming out of the lights AHHHHH!. Im willing to purchase another pair i just want to know what brand make them the best. These leds lights are JJR brand ??? Has anyone come up with this experience and please tell me how you fixed it. A place called Sports_lights in Melb are selling the LEds but i dont know if they are the same make. Could it be just the actuall pair i brought were defective? Because when i took it back they recon that they are aftermarket and they will never fit as good as new, I think thats bullshit ive seen heaps of aftermarket rear lights fit pretty much perfect. Can anyone out here give me advice from experince or word of mouth. THankss i feel like i just through $359 in the bin!
https://www.sau.com.au/forums/topic/184246-help-r32-led-lights/
take it back and complain if it doesnt fit
shud be covered by warranty dude.
and also u go ta gtr, why u wanna ruin it wiht led chrome lights for? :D
I now snapped the bolt and the leds look nice its not chrome The lens is still red the only thing you see diff is the blinker is clear and the leds coming out of the red lense. Do you think they will return it if i snapped bolt trying to tighten it LOL Do nismo sell led lights cause i know they will make the best ones, i cant seem to find where to buy them from.
Pic was straight off yahoo japan.
If you talk to slidewize in the business traders section I think he can get them for you..
Yeh i have sent them an email problem is if they dont fit perfect its hard to return, How will you be making your own lol
What do you mean by that? :mellow:
I mean, I'm going to make up a set of boards, rip a pair of the old housings apart and fit them in there.
look here for a set of 33 lights done diy:
http://www.skylineowners.com/forum/showthread.php?t=48788
his pics http://www.members.aol.com/mattyjeff/Auto/LED/
I'll be doing it a similar way, but giving the board design to a professional pcb manufacturer to knock out so that everything is identical.
His light use more led elements than the yahoo.jp pictures as well.
james.
REallyyy? how much would you charge if you were to put my led lights inside the old housing? THats EXACTLY what im looking for i just dont know who will do it.
james.
someone has taken second hand stock lights and then ripped them apart and put LEDs in them, so its gunna fit just like factory :mellow:
But i emailed Slidewize and he goes that they are aftermarket aswell and said nothing will fit as good as the NISSAN parts, so the lights he sells in japan are made out of china aswell, but he has never ha dcomplaints about them, i cant see all the lights fitting like shit. im just wondering i think it was a bad batch of JJR lights or something thbat i bought.
Worst timing ever!
I just ordered a pair of the JJR LED's a few days ago! Should be arriving tomorrow or tuesday, I'll let you know how they fit..
LOOL ay i want to talk to you about them please get back to me once you get them THAnKS!!!
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
