I brought LED TAIL lights for my r32 GTR from JUST JAP in Kirrawee, SYDNEY. They dont fit on perfect! one side fits different to the other side and I CANT STAND IT. I played around with the lights so much that i eventually snapped the thread coming out of the lights AHHHHH!. Im willing to purchase another pair i just want to know what brand make them the best. These leds lights are JJR brand ??? Has anyone come up with this experience and please tell me how you fixed it. A place called Sports_lights in Melb are selling the LEds but i dont know if they are the same make. Could it be just the actuall pair i brought were defective? Because when i took it back they recon that they are aftermarket and they will never fit as good as new, I think thats bullshit ive seen heaps of aftermarket rear lights fit pretty much perfect. Can anyone out here give me advice from experince or word of mouth. THankss i feel like i just through $359 in the bin!
https://www.sau.com.au/forums/topic/184246-help-r32-led-lights/
take it back and complain if it doesnt fit
shud be covered by warranty dude.
and also u go ta gtr, why u wanna ruin it wiht led chrome lights for? :D
I now snapped the bolt and the leds look nice its not chrome The lens is still red the only thing you see diff is the blinker is clear and the leds coming out of the red lense. Do you think they will return it if i snapped bolt trying to tighten it LOL Do nismo sell led lights cause i know they will make the best ones, i cant seem to find where to buy them from.
Pic was straight off yahoo japan.
If you talk to slidewize in the business traders section I think he can get them for you..
Yeh i have sent them an email problem is if they dont fit perfect its hard to return, How will you be making your own lol
What do you mean by that? :mellow:
I mean, I'm going to make up a set of boards, rip a pair of the old housings apart and fit them in there.
look here for a set of 33 lights done diy:
http://www.skylineowners.com/forum/showthread.php?t=48788
his pics http://www.members.aol.com/mattyjeff/Auto/LED/
I'll be doing it a similar way, but giving the board design to a professional pcb manufacturer to knock out so that everything is identical.
His light use more led elements than the yahoo.jp pictures as well.
james.
REallyyy? how much would you charge if you were to put my led lights inside the old housing? THats EXACTLY what im looking for i just dont know who will do it.
james.
someone has taken second hand stock lights and then ripped them apart and put LEDs in them, so its gunna fit just like factory :mellow:
But i emailed Slidewize and he goes that they are aftermarket aswell and said nothing will fit as good as the NISSAN parts, so the lights he sells in japan are made out of china aswell, but he has never ha dcomplaints about them, i cant see all the lights fitting like shit. im just wondering i think it was a bad batch of JJR lights or something thbat i bought.
Worst timing ever!
I just ordered a pair of the JJR LED's a few days ago! Should be arriving tomorrow or tuesday, I'll let you know how they fit..
LOOL ay i want to talk to you about them please get back to me once you get them THAnKS!!!
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
