hey all
i have a r32 gts4, recently did some brake upgrades which include:
RDA slotted / dimpled rotors all round, braided lines, cusco master cyl stopper, r32 gtr front calipers and ds2500 pads and new motul fluid.
the brakes seem to work quite well now, unless i hit the brakes quite hard and the rears lock up and the car has abs..
never needed to hit the brakes hard b4 the upgrade so dont know if the abs was working before.
the car has had a rb26 conversion, maybe thats got sumthin to do with it?
cheers
https://www.sau.com.au/forums/topic/184259-r32-abs-rears-locking-up/
Check the obvious stuff like speed sensor is still hooked up and the diff sensor is plugged in. If the wiring for the swap has been done properly it shouldn't contribute, but it's pretty common to have no speed sensor connected to the ecu after a swap.
R32 GT-R's brakes are somewhat rear biased and usually lock the rears first. So what you are experiencing is nothing abnormal, unless ofcourse it is happening with very little retardation.
Some questions:
How firm is the pedal?
Does the ABS release the wheel, ie do you get the usual ABS feedback through the pedal, albeit at a slow rate because the system is pretty slow?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
