hello all, ive lurked here before, using the search buton alot to gather info. Since skylines are rarer than smart presidents here, I can only pretend by owning a s13 coupe with rb20/5 speed setup. Just thought I would say hello after I've Lurked for so long.
https://www.sau.com.au/forums/topic/184349-newbie-from-the-us/
lol welcome... don't sell yourself short there... JFK was a smart president, dunno bout the mob that came after him though ;)
I've followed some of the buildups you guys do over there (mostly on ziptied), and I must say the quality of work and the attention to detail in some of the builds is really good over there. Did you do a face swap on your 240sx? how's support for the RB's over there?
yes did the face swap, as I dont care for look of the us. spec 240sx. as for support, depends on the Rb motor. rb20det=parts harder to come buy, engines themselves arent horribly expensive compared to sr20dets, etc. rb25det=more aftermarket support, more expensive engines and of course the rb26dett over here brings in a good amount of money and good amount of aftermarket support.
here are some pics, yeah I need paint, lol
Edited by 200sxRb20
nice sil, very close to a typical aussie street silvia. whats the paperwork like in regards to importing and installing a foreign engine?
is the 30y/o rule true? ive seen pics of all the old C10s and the like, how common are they over there?
i'm pretty sure that the silvia and sil80 were factory imports in america (hence the steering wheel being on the wrong side, LOL).
hey dude, welcome to the forums. don't take anything ctjet or myself say too seriously. we are the resident bully's of wasteland.
they are also lovers...
you're half right.... the 180 (240sx) and the onevia are factory imports into america
as apparently the silvia headlights were too low or something so they didn't meet the US road regulations
lol, the ninjas are my secuirty system. as for the silvia imports, we got whats called the 240sx coupe and hatchback, Ie the silvia and 180sx respectivley. the front end was swapped because of the headlights, and instead of the sr20det, we got what we refer to as a truck motor(same motor that was placed in the nissan trucks here in the us) the Ka24e and later on the ka24de(hense the 240 name). its kinda crappy, so most people do the conventional sr20, rbxxdet/t, or ca18det(as well as more uncommon v8 from various makes) swap.
as for the rules on swapping the engine, depends on the state/city you live in. if the area you live in does emissions testing it can be an issue, but depends on the test they do. if the car is a certain age, they only do the "sniffer" check, so you can get away with it with a cat. converter, etc. now if they do a visual inspection, well, they are obviously going to know, and you will not be able to get it registered to drive. Luckly I live in an area that doesnt do emissions area so I dont have to worry about it.
and the squishy pipe, nah its not the actual pipe, and now that I think about it, I cant remember why exactly I had that shield on there. I know it had a purpose at one point or another. but thanks for the welcomes, look forward to learning from you guys(and gals?)
and here are my mods just for reference.
RB20DET(from A31 Cerfio if i remember correctly)
ARP Head Studs,
GReddy 1.2mm Head Gasket,
GReddy Timing belt,
Fidanza adjustable cam gears,
Hybrid FMIC and piping,
Turbo XS BOV,
HKS pod filter,
3" exhaust with Fujitsubo NGK axle back,
GTR fuel pump,
Koyo radiator w/ dual 12" fans,
GReddy EManage,
GReddy Profec E-01,
GReddy Auto Timer,
HKS Hypermax D coilovers,
front camber plates,
Cusco front strut bar,
Cusco front tension rods,
Zenki Silvia front end conversion,
Silvia Dual Projector lights,
16x7/16x8 SSR Integral A2 wheels,
225/40-16 Toyo Proxes T1-S,
R32 GTS seats,
Sparco wheel,
R32 tach in S13 cluster
silvia headlights aren't DOT approved, 180sx pop ups on the other hand are easy to change to DOT approved ones. Rather than redesign the silvia headlight (so that it dosen't glare into oncoming traffic etc) they just replaced the front end with the 180sx front.
Guys in japan saw this and started copying the americans... and the onevia was born.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
