Lol they arrived on the same boat most probably because mine arrived on the 1st of Jan, taken to compliance around the 5th.
Purchased via Iron Chef.
Is yours going through in Sydney?
I went to the workshop a few weekends ago and saw my car so I might have seen yours as well.
Hey mate,
Im in Melbourne. Did you use Autohub? Our cars probably did come in on the same shipment. I reckon i would be ok with this wait if there was decent communication and clear justification why it has taken a month since they told me they sent off for the plates.
didn't anyone tell you that all clean and straight-forward, private/broker import cars automagically get targeted for "random" inspection? thereby holding the process up by several weeks.
The Department of Infrastructure and Transport's "random" inspection process is very important to ensure that while your car is being inspected all of the accident grade, wound-back dealer cars are ushered through the process without obstruction.
also - are you suggesting they should be held accountable for delays far exceeding their alleged "15 working days from receipt" processing target? LOL - remember we're talking about the public circus.
Btw, Im pretty sure that the RAWS team are contracted out by Dotars and are not public servants.
Not sure what auto hub is.
I purchased mine through Iron chef.
But if you are having the same holdups that Sydney is having then I feel a lot better. I guess it's a holdup with paperwork or plates and we just have to wait
When I imported early 2013, I had about an extra 6 weeks delay. Mine ended up being due to Dotars training " A new girl" as they had been understaffed for a while. They stuffed up the paperwork and had to resubmit it again........... Once Iron Chef got onto them it went much quicker after that :banana:
Very nice! Looks like you scored some decent rims as well. Is that a factory bumper?
Heres my new daily beast!
The cube! niceeee
Yeah scored some nice SE37's and suspension.
Factory series 2 bumper (This will be one of the first mods haha because it looks horrid)
My GTR took less than a month for compliance as it was relatively stock and i had no issues. Car arrived on Oct 9 2013 and was ready by October 26th. However I bundled rego into it to be done which took another week or so to do but I was fine with that which delayed the car from being released until early November 9. Purchased via Iron Chef.
The wait is always a killer, but you guys are almost there!
just thought id chime in as i believe im in the same boat as you guys you can check the status of your car via dotars "Search for Approved Vehicles" and type in your VIN which is on your auction sheet if you dont know it already, mine got approved on Feb 28th so im guessing 2-3 week till im registered.Its true the wait has been absolute torture, especially seeing GTR drive past, you absorb every noise sound and smell knowing soon this will be in your possession.........
Edited by IllestR33
They told me it should be this week but I still haven't heard anything.
Might try and find the auction sheets and get the vin number to do that check.
Lucky for me I have a nice and powerful 33 to drive for the time being haha but thanks heaps for the link
heya, you don't need plate number. just grab the chassis number from your auction sheet and type it into the 'VIN' field - remove any dashes, leave the plate number field blank:
eg. BZ11344272 or ER34025033
then hit search and it will return the compliance plate info. if the car hasn't been complied yet you'll get the "no records matching..." message.
Edited by dodgyimports
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
