77 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
hey guys!
for the past year and a half me and my mates have been having a disagreement
about the width of our tyres. my view was wider (265) tyres are better as there is more
serface area on the road to get better traction.
his opinion is that skinnier (185) tyres have more pressure on the road,
therefor the traction and handeling is better.
what are your thoughts???
Edited by SHY_33
https://www.sau.com.au/forums/topic/184439-skinny-or-fat-tyres/
  • Replies 42
Your mate is partially correct in places of limited traction like wet roads where a skinnier tyre will "cut" through the water to gain traction. A wider tyre will tend to sit on the water.
This is similar concept to when (in a wheels article) heavier cars out braked lighter cars in the wet. The greater weight on a smaller surface area assisted in traction.
On the whole he is wrong and the "stickyness" of the tyre has a lot more to do with it.
well the way i look at it is the v8 super cars dont put 185s when it starts rainig hey so fatter is still betta
i would say that is because skinny tyres are better only to a certain point, ie: if you put bike tyres on it will obviously not grip, but if you put 305s on with will aquaplane real bad, they must have found a happy medium with whatever they use
So far so good 1nce i get enough people and a few pages im gonna print it off and give this forum page's to him,
his a very close mate but he still shits me with the skinny tyres are betta, and yes he had 185 on his car now has 225 and wont say anything about the handaling of his car special cause its a vc comordor,
but whats funny it doesnt stop there we are into extreme 4wd and he has started it again likes of i had a patrol with 39.5x16x15 and he had 35x10x16 and he still says the same fact skinny is betta.
EVERY PLEASE VOTE
thanks john
Well everyone is wrong so far. It depends on the application and the car.
Why would wider tyres neccesarily make a car have more grip? Chances are with your hetik skyline with 10 inch wide rims that weigh 30 kg a corner cos you got them at wheel worx aren't going to give you more grip now are they?
So maybe in outright grip in a straight line having a wider tyre will be usefull, but would you rather have a 100 dollars 285 wide tyre or a pirelli 225? i think i know which i'd prefer. And when it comes to corners i'd say suspension plays a greater role in traction relative to how wide your tyres are.
So to conclude read and find whats the best match for your car.
It's just like getting a 200 intercooler off here or getting a 1000 dollar greddy or arc cooler. Sure the 200 dollar may be bigger but i'd bet the farm the arc would flow better and cool better.
You pay for quality full stop. but now i'm getting off topic.
arhhhh
Edited by kralster
arhhhh
are u taking wind resistant into them calculations , i think the question is in general do wider tyres have more grip than skinny tyres not do 225 goodyears on a supra have more grip than 235 falkens on a ford at 34.6759657842 degrees
lol @ ^
lets face it, the broad answer to this broad question is - wider is better.
your getting too technical.
think of it this way. these two guys had a few beers, watching ralph tv, maybe some cones, and then 1 says skinny tires are better than wide.
what do you do?
*SLAP* i'm rick james bitch
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
