Hey guys,
Sorry to bring this topic up again, But ive come across this unit on ebay.
http://cgi.ebay.com.au/DIGITAL-TV-TUNER-CA...oQQcmdZViewItem
this is what actually got me thinking about it ....... "This unit will work with any NTSC or PAL monitor with RCA input"
Does this mean it could work on our NTSC navi units?
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/
I read the user manual, and its difficult to know if it converts PAL into NTSC or simply it can handle PAL and NTSC inputs and output the same. You could try contacting the seller, might be able to help.
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3339744
it should work by the discription it is compatable with both pal and ntsc imputs + it has auto function what ever the hell that means? i think it means it will auto detect what your monitor is using. thats just my thought. and how big is the arial my dad bought a satlite decoder and yes he needs a satlite on his roof for that to work wilst driving he needs a auto detecting satlite worth 4grand. iam not shure about yous but i don't think rabit ears in side the car is safe or practicle and if you need a telly areil out side that is hidious. thats just some food for thought make shure you look into things before purchesing or you will be just giving someonelse a bargin when you have to on sell it.
Edited by petrolfix
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3339837
i think what it meant is its a multi system for the receiving signal. Not to he unit. ou might need to ask the vendor about this. Ask him this.
1. Is the unit able to be plug into A screen which is an NTSC format?
2. Is it able to convert the Pal signal into NTSC for viewing?
I have quite a firs bit of experience in AV thingy. If it is the convertor it should work. Hope this helps.
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3339938
if I read that correctly it will interprete the INCOMING tv format. yo need to find out what it actually spits out.
the on glass antenna will yeild crap results - a outside one will work better. rabbit ears are not what these things are btw. they are specialised ones that look similar to a small mobile phone antenna.
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3341735
I asked 3 different sellers in the UK, also a PAL and DVB-T area, about the same digital box, this one:
http://cgi.ebay.com.au/Car-Freeview-Digita...oQQcmdZViewItem
and they all stated that it will work on my NTSC screen.
However, the same looking product on this page, 1/3 way down, (DVBT-CAR )
http://www.threedoubleyou.com/car-tuner.htm
states that there are 2 different versions, one that outputs PAL and one NTSC, please specify when you buy.
Im keen to try one of these and replace my bulky tuner and converter box into this small unit which I hope will give me a more stable picture when im moving.
Edited by chook
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3345162
This is his reply
"Digital is neither PAL nor NTSC and so it will display perfectly no matter what (like DVDs)
These units are used by plently of club members and thanks for the offer.
The free antenna is average and will work depending on where you are in relation to the broadcast towers."
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3345490
I get a strong signal off my factory aerials in the rear and side windows (all bridged together into one at the plug), only thing is they need to be powered, this is usually activated when the factory jap TV tuner is selected. Therefore to use AV2 with the aerials, you would need to supply some power to the small silver boxes in behind the rear panels. (signal amplifiers maybe ??)
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3345508
This is his reply
inb short the aerial is shit LOL!!
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3345657
Installed a new TV tuner, to simplify my setup, as this one doesnt need an NTSC converter, so there is everyones answer ! will output in NTSC. I had to connect it to my home TV first to change the menu to NTSC, otherwise you wont be able to read the menu if you connect it to car first. Signal is average when driving around, perfect when stationary, although i am getting a better signal with my factory window aerials than the one provided in this kit.
http://cgi.ebay.com.au/DVB-T-DIGITAL-TV-TU...1QQcmdZViewItem
Also, had a whirring noise from the rear of my NAVI unit, seems my cooling fan had packed it in, replaced with this one, bolt in, just needed to change the plug over. Quiet and powerful.
http://www.pccasegear.com/prod5058.htm
Edited by chook
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3374496
And the unit is quite cheap too!
How did you go about hooking up the aerials to the unit Chook and was it easy to install?, where abouts did you install/mount it and most of all, how easy is it to use (ie: do you need to wire an infra-red eye to change channels etc)?
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3375159
The Stagea has 3 or 4 (cant remember) separate aerials in the rear glass, and the factory tuner box selects the best signal from one of these at any given time, called diversity aerials. Some more expensive boxes have diversity inputs, but are way too expensive. I just cut off the mini plugs on the aerial cables, stripped and joined all of them together into 1 cable and put a RF plug onto it. As I said before, these aerials have a silver box, possibly a signal booster, hidden behind the rear pillar panels, these get power to them when the tv tuner is selected from the screen. Without this power the aerials are weak. But we are using VTR2 ie no power, I found the wire, cut it and put accessory 12v to them.
There is probably better ways to get a signal but i want to keep mine as factory as possible, ie no external aerials.
The unit comes with an IR extender cable, about 3m, which i placed under the glovebox, next to the flare holder. All pretty easy to use.
For sound you just need a headunit with RCA line-in plugs, run audio cable from DTV box to headunit, or if you have factory headunit, just straight to the factory VTR2 plugs in the factory tuner box from the DTV box.
It all hidden in rear left panel underneath the factory tuner box.
https://www.sau.com.au/forums/topic/184496-tv-navi-unit/#findComment-3375791
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
