Take one for a test drive if you can....there's alot of models available from a 2.5lt NA, 2,5lt Turbo, 2.5lt Diesel, 3lt NA, 3.5lt NA. You will find that the 2.5lt Turbo's is fairly easly to get a hold of.....206kw and 410nm's....so there enough power there. If your really interested you should have a look to see wether you can get a brochure off ebay or something. Inside the car is something again....the Japs get everthing....dvd, tv, sat nav(these all need converting though)....see pictures.
P.S. If you are doing and import make sure you talk to a compliance place before purchase(don't go above a 2003 model...might also find you can only do the 2.5lt turbo)
Edited by Jetwreck
do a search for autech axis : all will be revealed there :P
there was a recent thread about a 2004 model stagea but i think the issue was the year it was manufactured - since ADR laws changed in late '03 or early '04 or something...
I too would be interested to find out if the VQ25DET powered stageas up to and including 2003 models are elligible for compliance here.
Off what I have learn't....from the begginning of the M35 run the VQ25DET was in it. If you want to confirm all detail contact Ben at North Shore Prestige on 02 9948 5302....good guy's
Didn't the VQ25DET come out on the 2001 stageas? Do you know if 2001-2003 models (earlier than 11/03) are compliancable?
Even though the car might be exactly the same under the skin, etc. right through from 2001 through to 2004, the ADR's work on build date, regardless of the fact that the car has not significantly changed at all. This is why they're stuck with trying (and failing) to comply with ADR79 - the rules changed at the beginning of 2004, and emission laws became a lot tougher.
you wouldn't have a pic of the engine bay at all... how does the single turbo work on a v6??? placement of the turbo?
bottom left of engine just in front of passenger footwell
very awkward to extract it's an engine out job as I've just found out
pays to keep an eagle eye on the air filter
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
