  • Replies 68
talk to terry at award gearboxes in rydalmere. he know his shit
did i put you onto a good thing there Dunc's?...yes the little "bikie" sure knows his stuff. When you see his shed you think...nahh this couldn't be the place...then you see the PPG sticker on the door and its like...well this must be the place.
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3350046
hey guys. just doing some research. which ppg gearbox would be the best to get? for a street/track gtr????
any personal experiances with them?
cheers.
How much power is in the GTR?
What the proportion of track/street? What tyres will you be using?
I've an OS synchro box and a ppg helical dogbox. The OS is ultra reliable if you have mechanical sympathy. The dogbox NEEDED & HAD regular maintenance. I've had my shares of failures with the dogboxes in my cars. I am currently using the OS in the GTR and will only put the dogbox back when my car is all sorted and I need to look for that extra 0.5 sec lol I missed too many track days with the dogbox :thumbsup:
The best thing to do is try to go for a drive in one. Dogbox is not a cup of tea for everyone. Even if you've mastered the technique, it is still a pain to drive in peak traffic. It is awesome on the track or times when you don't value your license.
PS: NOTHING is indestructible in the GTR :) Don't think that because you pay 10k for a gearbox it will never break down.
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3351659
yes very tru. its a difucult decision to make. what problems did you have with the ppg? and what bits needed replacing? did you have an ignition cut on the ecu for gearchanges? and did you use the clutch with it?
sory for all the questions. just want to get the rite one.
once this gearbox is in. it will be 70/30 track/street. thats what lary the laser is for :unsure:
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3351950
its going to be dog or synchro. not a combo. id probably get confused when racing going from 20ms shifts to a clutchless synchro shift and have the thing explode on me lol.
ive pretty much made my mind up on the 5 speed straight cut one. and i will utilise the flatshift function on my autronic to be nice to the box. also im in the process of designing a mega short shifter for the box as to speed up the changes. cos ive heard the quicker the better and less ware on the dogs.
how was the trust six speed to drive?
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3352251
It was quite a dog to drive. :laugh: You need to slam it in to get it to engage and would suit both your and my style of driving ;) Street driving was fun but I personally didn't mind it and put up with it. Although I only drove it for a few kms before it decided that 2nd had had enough. Further to that, my clutch isnt the easiest thing to drive so that is also a consideration.
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3352497
hey to4gtr
i love our ppg dog box, we use a stright cut 5 speed box with the billet selector forks and bigger input shaft. i have very little sympathy for the way i change gears especially downshifting when using gears to help you pull up when i'm really late braking! if i had a synchro box in my car now it would last about five minutes before i would break a synchro. also we always use the clutch for up and downshifting with the ppg box.
that said they are very very noisy. and harsh on change when just chugging around. Also as others have stated they still need maintenance, mainly dog gears wearing which require replacing or back grinding to renew them, everything else is pretty bullet proof.
i generally have been getting the whole year out of the box, then rebuild. we have never broken a ppg gear or part (although we did twist the smaller input shaft, but we always new we were on the limit with that) . I have broken one of the standard nissan oem parts that get refitted to the gearbox when you buy a ppg set , when this broke it went down between the gears when i was doing about 180kph and smahed every gear in the box including both cases and the sandwich plate!! destroyed everything!
cheers russ ( p.s if you have a run around car & your car is going to be mainly track, i would recommend a ppg box. make sure it is built well and thoroughly checked over and use a good donor box)
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3352792
hey to4gtr
Hey Guys still trying to get used to the box, just a qwuick question. When your just driving around normally(not on the track) do you find that you have to shift slowly and in 2 stages rather than just trying to smash it in like you would when flat out??
As it seems to be wearing in it is becoming a little harder to use around town.
Cheers guys talk soon
Matty
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3352994
the boxes are great, pretty well what russ has said about them is spot on, as we both know from experience. Dog rings wear like a mofo, but as said they can be cleaned up to be used again before having to replace them. Full set of dog rings is about 1k.
I finally got over the mental block in my head about changing with the clutch on upshifts. Fark its great, change so fast with just a slight lift off the throttle. Pull the lever easily and it just slots into the next gear, so long as the revs are high enough. I found in the lower revs if your changing without the clutch, you need to rev match with a blip so it slots in or else it will crunch also. Obviously rev matching on downshifts is a necessity and used in conjuction with the clutch.
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3353006
Matty
matty
when we are just chugging around, i have found being really forceful with the change is best. If i just lazily put it into gear in most cases it will chatter on the dog gears and feel rather harsh. best to be acertive with it even at slow speeds.
cheers russ cya soon , congrats again mate on the pittsworth win!!
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3353579
AWSOME. thats what i figured. yeah il be using the clutch, and using the flatshift function on my autronic. (ignition cut for 10-200 m/sec time apon depressing the clutch.)
is redline oil the go? or that expencive motul one?
https://www.sau.com.au/forums/topic/184656-ppg-gearbox/#findComment-3354263
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
