Stillway in Japan make a gear shifter that locks out 1st and might be applicable in this case.
Thanks mate, trying to find the product but not having much luck. Will def buy one! Do you know of any in aus?
Has anyone on here used an Ikeya Formula sequential shifter with a ppg box?
Edited by PJ.
  • Replies 68
Yes, the Ikeya is no good with the dog boxes.
The Stillway shifter works by locking out the gear that you shift up from. ie, 1st to 2nd cant go back into 1st; 2nd to 3rd, cant go back into 2nd; etc etc. This allows you to not miss shifts as you go up through the gears and effectively becomes a 'sequential' H-pattern box. When you want to go back down though the gears, you can do so up lifting the lock ring that is on the Stillway shifter and then engage the lower gears. It is mainly aimed at drag racing so that you don't shift into, say, fifth gear when doing the 2nd to 3rd shift.
I went for a massive fang last night (on a track of course) not using the clutch for both up and downshifting and I'm really loving this box now.
My mechanics put a much firmer relocating spring in the box so it neutralises a lot harder after I pull out of second. I still use the clutch from first to second though as it seems to clunk a bit otherwise. Can't wait to drag it again now, I'm sure there has to be a tenth or two in the gear changes alone compared to the syncro box.
Do they have a hp rating on the helical dog gearsets for a GT-R/GTS-T box?
What 60' and et?
Shocking 1.955 60ft, track was prepped to the max so I needed to turn the anti-lag up a few more psi but didn't have the laptop handy at the time. 10.658 @ 137.60
I bogged every run! Prior to that I ran a 1.69 60ft so next time I go out, it's on!
M/T 255 radials
Edited by PJ.
  • 6 months later...
Im happy to say i fixed my oil being pumped out the breather pipe problem on my ppg gearbox... What i did was add another breather pipe to the inspection plate on the top of the box where you can see the selector plate... I then ran both breathers up to a high point in the engine bay and now have no loss of oil from either pipes no mater how hard its being driven...
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
