I own a GTST Series 2 R33.
Does anyone own one aswell and is running a slide highflow?
Compared to stock turbo how much laggier is it?
What sort of kws u getting out of it?
How long u had it on your car for?
Mods Include -
POD
FMIC
Power FC & Controller
Apexi Boost Controller
Soon to have 555c injectors
Would i need anything else? would it puch 260kws on a SAFE tune?
Thanks
https://www.sau.com.au/forums/topic/184705-slides-highflows/
My cousin has one on his R33, just with cooler, turbo back exhaust.
Doesn't seem muc laggier, only a little.
Pulls very strong on boost all the way up to red line. He has had it for at least a few thousand km's with no issues.
I also want to get one for my R32, but SLIDE doesn't make any high flows anymore..
VG30 max over size high flow would be better for 260rwkw and above.
Edited by abu
But GCG do Ball Bearing not Journal... so itll spool like 100-200rpm faster or someshit like that.
If you ask GCG maybe theyll do a Journal Bearing for cheaper.
Edited by Pauly33GTS-t
Yep same problem here.
Not I am also undecided on what to get.
Just a a HKS2530 or something similar to that, maybe even a HKSGTRS.
yer my problem is i dont know enough about turbos to make a good decision!
If you are only looking to make 300 rwkw or less i would vote the GTRS or the GT28rs hands down.
Anything over this and you would be looking at something like the GT3071 or something similar.
From what i have read these are the two best turbo's for around the 300 rwkw mark without losing too much driveabiolity as an everyday car.
Guest
    • Yeah, I still don't know why the idle speed control can't catch the falling RPMs. In the Consult logs I see the AAC duty cycle rising, but suddenly it goes lean and the engine stalls. Anyways, the relevance here is the DW 550cc injectors are probably the same. So if OP has similar issues I would be tempted to finger those injectors as problematic for whatever reason vs the ECU failing for some reason.
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
