Sigh, well somone smashed the window on my baby tonight in the work carpark :) but they didnt take anything or go through anything so i assume the alarm scared them off, wouldnt suprise me if it was some pokie fiend looking for coin. Happened in the last 45mins a(around 12:30)of work as i checked on it a few times before then.
So iam looking for a drivers side window for a 33, going to ring around tommorrow and get a few quotes anyone have recommendations ? and a rough guess on how much it should cost to get fixed ?
https://www.sau.com.au/forums/topic/185487-ma-baby-got-mauled-at-unley/
Exact same thing happened to me about a month ago.
Broad daylight on a friday afternoon in my work carpark in a very nearby suburb to where yours happened.
Pager alarm went off, and by the time I got downstairs was time enough for them to get back into their stolen (according to police) maroon r32 (I took the rego plate details), which I saw leaving the scene in a very suspisious manner.
I got a new window from import spares (sleaford rd, windsor gardens) for $110, and fitted it myself.
It pays to ring around, as prices varied to double what I ended up paying.
Not a hard job, but also not much skin left on my knuckles afterwards.
Worst part is that there seems no way of easing this spate of import break-ins.
Police say that they have caught the people responsible, and then guess what.....
Sorry to hear that mate, I can empathise, Deluxe and I were recently victims too literally in our own backyard in the same area. We got off with damaged doors.
http://www.skylinesaustralia.com/forums/in...howtopic=185076
Edited by Oosh
Damn this stupid shit!!
Don't leave your cars in that area people! i remember seeing a silver/white(it was night time) 32 follow me into my street and almost watch me reverse into my driveway! I just thought it might have been one of you guys coming to say "Bloody G'Day" but when i got out of my car, the 32 took off slowly! I did put it up into the spotted section but with no reply, so now after reading this i thing they either have lines themselves or steal them to get to another one!
So if there is some scetchy suss c#$t in a Skyline checking you out more than what he/she should be, go smash thier heads in and go from there.....lol
yeah :) shittiest when it happens at ya home or work makes me :dry:
All fixed now tho. But it the glass breaking didbit of damamge to the paint work ;) still have the car to so yeah :)
sorry to hear good news nothing taken but still a hassle and now while @ work you'll be ever wondering will they strike again
obviously thieves are blind too and cant see a flasher or think maybe its not real ill try my luck and do smash and grab
my missus window was smashed at her house in her own driveway. stole a few things and damaged a far bit. used 2 screw drivers in the window seal and lifted it till it shattered on itself.
was a headf**k more the anything
sorry bout your car man
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
