  • Replies 63
yeh i took my new 33 for a speed test, i got to 190 before shitting my pants and slowing down for the corner (soft i know)
not sure wat revs i was on, but it felt f**king fast on a bumpy country road with coilovers
lol... when you DO get your license, make sure you get a daewoo. Its about the only car you should ever touch... and when you get that thing to 260... and the rattlles start... then maybe you can think of upgrading... to an excel
noob
sell your car and buy a scooter. would suit a guy with ur inteligence...so was the drunken idiot the driver or the one playing with straws...
It turns out that the rattling wasnt related to the speed as much as the 7 trillion mc donalds straws that my dunken idiot friend thought it would be a good idea to stick down the vents.
This is still going :) . Straws eh???? punch your friend for having no respect for your Hyundai and tell him to stop stealing from your work. Remember to wear safety glasses, one of those straws could take an eye out
the unfortunate thing is some poor noob is going to search for "Air conditioner rattle" and come up with this thread and go looking for straws in the AC vents.
lol
:( I didn't think of that. haha
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
