Hey Aaron, since when does $1299 - $1149 = $300 (JJ prices)
lol @ your maths. What is it you do again?
lol yeh whatever.
i wouldnt justify it even if it was $50 more.
the only difference between them is is the centre cartridge size, BR's hold more oil and the smallest of amounts at that.
same settings and everything else.
Yep thanks for that Leon. I saw the V1's, any noticeable difference in ride or adjustability?
No, I think the V1's work exactly the same & a few guys have been running them for a while now with no probs.
However, Paul @ STT won't sell them 'cause they are "unproven". What? I think they've been around longer than the BR's lol.
I think he likes the bigger damper (maybe thinks it will be stronger?) and I suppose our cars are pretty heavy.
In any case the options for me were buy the BR's from him or spend more money & get the V1's from JustJap. No brainer in this instance.
Edited by Commsman
lol yeh whatever.
Haha, yeah, I'm with you. Mainly 'cause I liked the colour more though lol. But in the end I got the other cheaper anyways (see previous post).
Edited by Commsman
i rekon the cartridge is different.
if yours is set on 9 from the hardest setting, and youre ok with that. mine would be rock solid.....
You may be right Iain. Scotty runs his V1's on about mid setting (15?) from memory & says very compliant.
mines rock solid at 9, i have mine set to 15 pretty much and its still firm.
perhaps you should also check your spring load, this would definitely add to its stiffness
theres no difference bar a few ml extra of oil. its so the oil can run cooler. which doesnt make a difference unless your tracking the thing.
and STT cant provide a warranty even though they said they can, he is NOT an authorised dealer.
dude its the same man, im telling you.
check your spring loading. mines only just tightened up. and 15 all round pretty much its still firm but comfortable because of the springs.
everythings the same man
Hello, this is news to me.
I doubt it's a problem tho. I mean, he's ordering mine direct from the factory (I know 'cause we were discussing spring rates & what was available) & I'm pretty sure he would send them back if there was any issues inside of warranty period (which I doubt).
His whole business is based on trust / word of mouth etc. You don't throw that away over a few hundred dollars.
my springs are set so they are captive in the seats, very little preload. and i can tell the difference between damper settings and spring pre-load :P
i still rekon they are different. only one way to find out!!
I was told otherwise, being BC's i dont think anything could go wrong but yeh...
come down to melbourne and say that :whistling:
ok so the difference is the diameter of the damper. bigger cartridge and more oil. yes aaron, a significant amount lol
What spring rate did you go for Leon?
2kg/mm less than standard at both ends, so ummm 10 & 8. At one stage the factory said they didn't have any 10's so I was looking at 8's F & R, which is very close to the Nismo rates I think.
Would have been pretty happy with that as I reckon Nismo probably know their product, but in the end they found some 10's & that's what coming.
My prediction: - No one will be able to tell the difference if they drive mine & compare it to their standard BRs lol. 2kg/mm will probably make stuff all difference. I think it will all be about the damper settings.
if thats the only difference, then to me, thats no difference. seriously a couple of ML's of extra juice isnt something to sing and hoorah about,
not to me, and chances are not to a lot of people that dont contstantly drive on a track unlike yourself.
like I said I couldnt justify the extra cost so i didnt get the BR's, but thats me.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
