yeh i might thats a good idea greg.. but thing is i wanted to complete the hks exhaust thats why i was going for the hks front pipes.. i want the car to be all one brand and since its got some HKS gear i thought yeh why not just keep it all HKS...
meh its only a front pipe i guess!!!
also greg the 33 has trust front pipe with a custom dump off the turbo... so its not just a cheapy one lol... i wudnt change it until u change the rear housing if u were to go down that path.. personally id go tomei poncams first, i think u will be happy with them :(
  • Replies 204
Posted Images
man im trying to find HKS front pipes to complete my exhaust (only cat back) and geeeee's they are expensive.. whats the normal price of a front pipe? i know its a GTR and hence more complex pipe and little more $$$ but man they are like $600 is this normal?
Dude you have a R34 GTR, brand name parts only!
lol i know james... hence why im trying to find HKS one at a good price lol
on this car it will all be brand name shite!!! needs to be :D
i mean my old car was all brand name, the only thing that wasnt were the castor rods i went cheapo and got just jap ones but they were ok...
Edited by mass_iv
Wil, when can you take pics of -MONA'S- new beast? hehe wudnt mind seeing some pro shots of it...
When's good for you? I'm a bit busy on Friday nights, Saturday's and Saturday nights with the reno.
when im finished with the engine so i can come for pics also.
Wink: wheels looks hot..
How long till the engine's ready? :D
haha yeh it flew up pretty fast and high huh
john, done.. ill wait till ur engine is ready.
Okies. lol
custom ftw.
hehe.
..yep, I read the brand name only thing... I just couldn't be bothered requoting, and changing what I was going to type. lol
haha that wud of hurt....
see the whoring has begun
And so endeth the thread. Sorry guys but the whore threads were killed for a reason. They breed bad social behavior. Nothing bad here yet but it's only a matter of time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
