pft, no one lives at Newtown :)
Jks! Yeah I dunno... Ask some newtown people I suppose...
Maybe send a message to [uLOOOK] (i think) on the forums... or Guilt Toy, he lives up that way now too ;)
(For the record, I'm actually talking about Newcastle)
  • Replies 409
Posted Images
It's not that strict... We were moving cars in all through the night last time, they know what it is damn near impossible for 12 people to all be there at the same time...
But yes, I was going to post that email... I suppose anyone who supplied an email got one?
Rar :)
We have to set up first anyway... I didn't write a move in time, so I don't know where they got that, but the are won't be ready by 4...
But then again, we can move some cars in and work around them if need be... It really isn't that big of an issue...
just received an email from autosalon notifying me that the "move time" is 4pm tomorrow. is this the case for all us in the skyline group? or ppl have different move in time?
Yeah they just do that as a rough time..It never goes to plan tho... Pretty sure we had the cars in the pavilion while we were setting up, cause usually a big line up all night :rofl: When ever you get there just try and move in where our display area is....
I am bring the flooring around 7pm as we are all to busy to get the flooring there any earlier :rofl:
hey guys i will be there on sunday as a spectator so see you guys there and it will be nice to meet you guys my name is Dale by the way.....
Awesome see you then!!!
Just turn up whenever. They will still let you in late at night even. I got in last final battle at 10pm.
I am demoted to CO :(
Anyways, I just got back from setting up the show... i was so busy I TOTALLY forgot to take ANY pictures...
My legs, feet, back, brain and bank balance hurts...
I was talking about his friend!! I didnt catch his name and that was at lunch time that I made that post when he came to pick up the not needed flooring :huh:
Shame about so many people pulling out last minute..
Would really like to see the entrants get more involved when its there cars they are displaying!!
Jay and the company he works for have been really great with the very generous expensive lighting and plasma's!!! Thanks heaps Jay really appreciated it :):)
Thanks to all that entered and Doof for all his organising :)
hey SAU'ers...tomm. the "twoogle" is going for the world power record for a low mount GTR. Good run today with the rich tune, made 650hp/485kw...will make over 500kw tomm. and set a new benchmark. But..tonight we must party!!
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
