does anyone care that i dnt own a skyline anymore? I'll try and get some of the guys from NS.com to come along too
not really, bring ns boys.... im looking at some silvia's in the future anyway
Edited by skyline17
  • Replies 42
From the Hills i know of two good cruises:
1. Taking Old Northern Rd to Wisemans Ferry. It's a nice ride up through Middle Dural and Glenorie, smooth & windy road :P
2. Taking Windsor Rd into Windsor. Similar story here.
Both routes have nice views too.
Anyone interested?
1. Taking Old Northern Rd to Wisemans Ferry. It's a nice ride up through Middle Dural and Glenorie, smooth & windy road :P2. Taking Windsor Rd into Windsor. Similar story here.
Anyone interested?
this sounds like a good idea...
If a couple more ppl are in for Wiseman's Ferry then we're cooking with gas.
I'm trying to organise some more ppl at the mo. Check the last Wiseman's Ferry cruise fir comments about it, in the NSW events section.
At least 5-6 people is a good start.
If you are going to cruise to Windsor you might as well do the little extra and do Bells line of road.
Cruise to wisemans via Galston is fun.. did it on the public holiday Monday..
Yeah i was up for that untill i realised it started 2 hours before i read about it :laugh:
Yeah wisemans ferry sounds good i'm in also and i'll drag SAM916 out aswell . . . unless its a sunday i don't do/work sundays
i've been spoken for.....but i'm up for a wiso cruise, even better if we get galston in there. I'm not from the hills area, but i'm there enuf :laugh:
+1 Il be in for this.... Sam, please sms me if it happens! Im picking up the line tonight or tomoz morning!!!!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
