  • Replies 191
im after the factory 6 inch rear inserts for the standard speakers(for parcel shelf). with covers/ nuts. do u have? if so id like em.
Edited by R33GOD
Finally found something i want, the big divider panel between the boot and where the battery and fuses are, how much just for that and does it have any cut outs or anything in it?
u mean the big mat thingy ?? i dont have that anymore if thats what u need :laugh:
buy something else though :D pls.... :(
nah my car just had external kenwood speakers. they were crap :laugh:
errr, its not a mat, its a bit of wood covered in carpet, i would put it in with the trim that goes round the inside of the boot, covers the attery and fuse box and in a lof of cases, including mine, it is where ppl mount amps.
ya nah i dont have it anymore sorry.
