everyone knows how horrid the r34 gtt stock gauges are so im about to replace them with a set of defi gauges. if i purchased another 2 i would get a good deal.
so the question is, what 5 gauges should i get? i understand that boost, water pressure, oil pressure, exhaust temp, manifold pressure are popular ones.
basically what 5 gauges would u set up in your car if u had the chance
Edited by R34NRG
https://www.sau.com.au/forums/topic/186440-defi-gauges/
Ive got defi's for my r34gtt - boost / water temp / oil pressure / oil temp / big defi tacho with shift light
only other one im looking at getting is exhaust temp....helps you know when your about to melt things :domokun:
have u got any pics mate? would love to see em!!!!
wat colours did u get?
me personally am going for the red set
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370313
1. PSSSHT value
2. CHUCHUCHUCHU-meter
3. +40PSI reading boost meter
4. 8"-12" monster tacho
you know me, id get em if i could :domokun:
do we have any SAU traders that sell defi guages?
would like to compare prices
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370336
havent fitted them yet to the r34 yet took them out of my ceff when i sold it and now i have the r34 i'll whack them in when i get some time (and a sandwhich plate)
i went the white black outs exept for the tacho its the other version as they didnt make a black out tacho (bugger)
got them through cj motors off the silvia forums he's in brisbane and super fast turn around for stock...i highly recomend him.
apparently the exhaust temp will also give you a hint as to when stuffs leaning out...or so ive been told by a few workshops so im looking into sourcing one before i install the rest of the set..
be sure to post pics when its done man!!!
they been going for around the $215 mark but ive seen some for $250.
how much did this brissey guy give em to ya 4
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370357
I have,
Oil temp
Oil pressure
Water temp
Exhaust temp
Fuel pressure
Turbo
5 mounted in the centre part where air cond stereo etc used to be
and near the a pillar
you've also got to mount the control box somewhere too. so keep that in mind!
but this is in a 32 gtr
Edited by Angus Smart
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371362
im not a expert but could someone explain why oil pressure would be more importent then......lets say for arguments sake manifold press?
just to get a better understanding of what my setup on my type of driving could be suited for
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371579
manifold pressure would be quiet similar to boost pressure/turbo... (i think)
oil pressure is probably the most importiant out of the lot, without pressure how are your internals going to survive!!
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371604
Because low oil pressure is a hell of a lot more pressing problem than low manifold pressure and indicates a serious problem such as oil pump failure, oil surge etc. Something you'd be really keen to playback after a hot lap.
Besides the manifold pressure gauge is for a NA car if i am not mistaken.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371619
Horrid? Nope. I think they aren't bad for stock gauges unless you are aiming to impress Paul and Vin when V-tec kicks in yo.
Admittedly I've upgraded to the Nismo gauges but hey, they work.
I'd like to see -
1. Dose/flutter meter
2. KM's to Noble Park Macca's
3. RPM till V-tec kicks in yo
4. $ left till I've payed the car off
and last
5. Number of Bush cops I've noted on the way to Noble Park Macca's
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371650
Because you car's blood is oil, no oil = dead engine. Low oil pressure = problems so it's nice to know what's going on.
Manifold pressure means nothing unless your floor pan falls out when you exceed it's limit, most likely from too many NOS shots.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371664
If your oil pressure has dropped off, the damage is already done.
Especially @ 7000rpm. IMO the oil pressure isnt that much of a help (over the stocker gauge). As ye, once you've done your dinner... thats it.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371668
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
