In the next month or two I am going to seam weld the chassis in my car. Obviously first off I'll be removing all the sounds deadner before I begin to seam weld the engine bay, floor pan and boot area. Before I begin though I have a few questions for those experienced that have done it before.
- Does the car require to be lifted off the ground and if so is it critical that the car is completely level before seam welding?
- Would the car benifit from being under tension from strut brace towers and B pillar bars before welding?
Any one who can point me in the right direction and give me some tops would be appreciative.
Cheers,
Scotty
https://www.sau.com.au/forums/topic/186468-seam-welding/
From theory if the car is seam welded while under tension from adjustable strut braces (front/rear), tension rod (front suspension) and B pillar brace. The shell typically should be held in place once the car is seam welded and I guess would benefit from being on the ground as to add more tension to the chassis. The interior and boot will be welded with the motor in it to give it more realistic circumstances ie. having the weight of the motor on the car. Motor will be removed once this is done and seam welded seperately.
The cage that will be put in wont be a stressed member, so won't be in there while the car is being seam welded. It will probably be a 4 point half cage for the time being once the car is being sorted, with an additional 2 points, extending over the drivers head, through the firewall to the front strut towers once the car is further sorted (I don't like 6 point full cages with points located near the drivers foot). Considering having two of the rear points extending to the rear strut towers as well. This is just theory for the time being before I have a set direction I want to take with the car. Just wondering on how others have done it before I head off and do it myself.
Will be used for drifting btw. Recently obtained a R32 RB25DE motor which hopefully will convert to a RB30DET with a GT35R. Which I'll use in the car
Edited by Baz
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3371164
Well we found the rear strut towers easy to get to, nissan gave us holes in the rear bulkhead to go through. 1 bar between the c pillar/wheel wel lmeeting point and a second bar between the 2 strut towers like a strut brace. Then 2 bars to tie them together as a square. Triangle would be better of course if possible.
Front on the other hand is a disaster. Need to move the brake booster and ABS if you have it for a decent triangle to the struts. Or there is an option to run a bar in the inner guard to the front strut tower from the A pillar bars.
Be really careful with the cage design even if for drift. There is a school of thought within CAMS that having an unapproved cage is more dangerous than no cage at all - and they may ban cars with unapproved cages. At some stage that, together with someone noticing that drifters do get out of first gear (unlike motorkhanas) will end up having your car banned.
Main point for that is front cage legs must be at A piller and can only have 1 bend from the roof
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3372689
Interested to see your results.
Are you going to be running a oll cage? I personally wouldnt bother seam welding a car. Sure Skylines arent the most rigid things...but you will get a lot more out of a simple roll cage...it woudl increase rigidity but i would not think by a massive amount.
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3373051
You would be surprised by the amount of rigity that you would get by seam welding a car. It's something which many people really dont do. Due to the amount of work stripping out the car, removing the sound deadner and then getting access to a MIG welder to do the spot welding along the seams. It will be getting a roll cage but as Duncan said before its regardless of how you are at fabrication, if its not CAMS approved then you will basically be turned away from many tracks. This is why I've considered getting a bolt in jap half cage, may not be CAMS approved but they have some marking that I'm aware of that allows people to use them at the track. They are unfortunately only of 38mm thickness (I think) which is below the CAMS requirements for a cage.
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3373359
i know one of the ae86 drifters in perth, (i think it was ken) has seam welded his 86 may be worth getting incontact with him and asking him the question.
Yeah I've actually driven Ken's car before :( Thats where I originally got the idea from. The car was just so stiff and rigid and also insanely loud as well lol. The only difference is that I'll probably leave a lot of the interior inside the car, so that its still loud inside, but doesnt echo like Ken's car did. AFAIK Ken seam welded his car on a hoist. Was just curious how others have done it.
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3373446
Yeah I've actually driven Ken's car before :P Thats where I originally got the idea from. The car was just so stiff and rigid and also insanely loud as well lol. The only difference is that I'll probably leave a lot of the interior inside the car, so that its still loud inside, but doesnt echo like Ken's car did. AFAIK Ken seam welded his car on a hoist. Was just curious how others have done it.
not sure if this helps but i have an option special dvd which is all about ae86, on one of the dvd they have the WORK BOX ae86 buildup and when they do the seam welding on the ae86 its just on the floor on the rims (and i think at one stage it was just on axle stands)
Also a friend of mine with an red 86 coupe POP Rivets his car while it front half was on axle stands and the rear half on the rims. and that turn out awesome really stiff.
so i think you should be fine if you cant get it onto a hoist to do it
edit: http://www.v-opt.co.jp/86.html check out this link as it has some sample vids of the dvd hopfully got something on the seam welding or else if you want a copy of the dvd i can burn you one
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3373470
Would anyone know how much approx. to get a skyline seam welded? i am quite interested in $$$ amount as i have considered getting it done in the past, but was too lazy to do anything about it.
do it yourself its not a hard job, not sure what i workshop would charge you but im guessing it will be alot of coin because they will have to strip the whole inside of your car, also if you want the engine bay done they might have to take out the engine = big dollars for labour
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3373492
One peice of advice I got from a mechanic friend of mine who has seam welded up a few cars is do it symetrically, ie. do one spot on the left hand side of the car, then move to the exact same spot on the right hand side and spot there. Doing this stops the car twisting as one side tightens up while the other stays slack.
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3373662
ive seam welded a few cars for speedway made my own rotery frame to mount the shell on so you could spin it around . seam welding made a huge diffrence to cars there is a lot less flex even with a full roll cage the suspension actually gets a chance to do what it;s designed to do instead of been soaked up in chassis flex . also makes the car stronger in case of a a hit once we seam welded a chassis we actually had to change spring and shock rates it made a far nicer car to drive . i suspect it would be the same on a drift or circut car as well . imho it is well worth the time and effort
cheers mid life crisis
https://www.sau.com.au/forums/topic/186468-seam-welding/#findComment-3373702
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
