Has anyone run a twin exhaust on there 33? not on the same side running one to the left hand side and one to the right?
Is there enough room down the right hand side to run it?
At the moment i have a 3inch stainless steel exhaust so i thiugh of joining in after the cat to run another 3inch pipe to the right, but unsure if theres room.
and i only wanna do it for looks
https://www.sau.com.au/forums/topic/186534-twin-exhaust/
yeah i've done it, it's a mission but.... got it sittin at home cause i pulled it off as it was heating up the boot pan too much and has some clearance issues when going over big bumps but it is possible
oh ok nice.. do you have any pics of what it looked lik?
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3371735
brilliant.
why not buy a cannon muffler, and cable tie it to the other side of the rear of the whale?
ALA Corolla's and civics bro.
then you got da looks and not da cost.
good izdz. but wat about running two cannons next to eachother? kits available. increases midrange torque.
dont worry about gtst man, just ignore him he never says anything positive.
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3374906
Can you explain how that would increase midrange torque?
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3375165
Im interested in the response to that aswell.
I dare say the answer will be 'interesting' :sorcerer:
But yeah, as GTS-T said.
Just put another muffler on the side if you want looks. No point hooking up pipe to it all as it wont offer any gains, add weight, and cause the car to be low and hard to get over speed humps etc.
So just get the angle grinder out and cable ties and then you'll have the looks
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3384198
I've got a twin exhaust, be warned though that it's neither cheap nor easy to do. Mine is 3" to the diff where it splits to 2 x 2.5". I've made modifications to both the rear bar and the spare wheel carrier to make it fit properly. The exhaust work was done by Mercury Motorsport in Brisbane.
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3384731
Hey man.. don't be so negative. :(
it will produce more midrange torque due to the way it's designed.
because there are 2 pipes it means more money was spent.
this in turn leads to lighter wallet, a feeling of stupidity, and a the need to lie about it to people you don't know on the internet.
therefore, applying the formula:
need2Bdifferent + feelinstupiddue2xtracost = need2lie2intraweb.
this forumula then manifests itself in to the theory we call "thefirstbullshitreasonyoucancumupwith"
Therefore, twin exhausts = increase in midrange torque.
You should know this man..
Edited by GTST
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3384804
Hey man.. don't be so negative. :dry:
skoold'
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385109
gold
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385160
This Thread is a prime example of why each skyline state needs a fight club meet every 1/4 or in laymens terms every three months. So everyone who goes on the cruise to enjoy their cars and other peoples cars also has an option at the end of the cruise to enter "The Ring Of Internet Heros".
So at the last meet point theres a ring set up and who ever has gripes or what not deals with it once and for all. The loser gets to shut the f**k up.
Thus ending the needless (countless) communications and clogging up SAU forums. So put down your keyboards and raise ya fist's and do it the old fashion way.
+1 :dry:
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385186
+1 :dry:
Wow this has taken a turn i wasnt expecting.... All i wanted was a few pics of what the twin exhaust looked like... the veilside was a great example, love the look of that....
People want different things out of there cars, i wouldnt have a go at you GTST what ever you wanted to do to your car, even if i thought it was a bad idea... Why you have to come into peoples thread and say stupid s**t all the time is beyond me. dont you have anything better to do? You worry about your car and ill worry about mine, cos at the end of the day ill forget everything yopu have said and only take in advive from the people who know what there talking about
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3385251
I thought it was a stupid idea..
people are so f**king sensitive these days.
you didn't like that I didn't think you had a good idea?
Go have a cry emokid!!
for f*ks sake
+1 for meetup beatings.
https://www.sau.com.au/forums/topic/186534-twin-exhaust/#findComment-3386556
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
