wondering if anyone knows a garage or garages who is capable of doing 4 wheel aligning around the ozzy park to wangara area. i been to wilkinson's suspension previously and its just a bit to far away for me to work around work and dropping the car off.
cheers guys
https://www.sau.com.au/forums/topic/186615-garages-that-do-4-wheel-aligning/
WA Suspensions in Ossy Park comes highly recommended.
Ask for Brad, a SAUWA member who works there.
+2 for W.A. Suspensions, they fitted my GB Whiteline kit and got it working well...and Rod And Brad are good guys
brads far to busy whoring to do any work
LOL with all his whoring you will be surprised how much work he gets done through the day, i would be happy to get half as much work done in one day as he gets through :)
im confused on why your searching for who can do 4 wheel aligning? i mean I used to do wheel alignments and with the electronic method in order to be able to do the front wheels you needed sensors on the rear wheels in turn give you a front and rear end result which will display camber, toe and caster on each corner of the car
so by saying that im confused on why it would be hard to find a 4 wheel aligner? unless your looking for reputable ones.
Edited by BANGN
I think it was more of a "who is reputable".
People ask for a 4 wheel alignment as there are still some shops out there who chuck the heads on the front, set the toe and send it on the way without a concern for camber and castor. You and i know better, however people are just asking for the best alignment so they ask for a 4 wheel.
In this particular case Joel asked for a 4 wheel alignment as he knew the front and the rear needed setting up so all though the term used may not 100% correct, its a term everyone knows and understands. :(
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
