  • Replies 99
  • 3 weeks later...
greygirl:
as i said before im interested in your car but distance seems to be a problem, ill ask my old lady what she thinks.oh i forgot to mention, is shipping the car interstate possible cause it be a pain driving it to adelaide. if so, how much will it cost?
